What is the wavelength in pm of an electron traveling at 60% the speed of light?
To calculate the wavelength of an electron traveling at 60% the speed of light, the relevant equation is wavelength = h / (mv). The Planck constant (h) is known, and the velocity (v) is 60% of 3.00 x 10^8 m/s. The mass (m) of the electron is constant at approximately 9.11 x 10^-31 kg, but relativistic effects must be considered at high speeds, which can alter the effective mass. Understanding the difference between invariant mass and relativistic mass is crucial for accurate calculations. The discussion emphasizes the importance of using the correct mass value when applying the formula.
Knight226
Calculate the wavelength, in picometers, associated with an electron traveling 60.0% of the speed of light.
Wavelength = h / (mv)
I know the h value.
The v value I believe it is 60.0% of 3.00 x 10^8
But what is the m value? If the m value isn't given, then the equation can't be solved, can it?
Is there a specific number for the m value?
From the examples I have seem, the m for electrons are always different.
Please help. Thanks in advance.
On the contrary, I am quite confident that the masses of electrons are always the same. It is the energy of electrons that changes.
The only time in which electrons may seem to have different masses in different questions are when an unfamiliar unit of measurement is used, or a different amount of significant figures is used. Nonetheless, the values should be relatively the same.
What is the equation for mass increase as a function of velocity? How much does the mass increase at 0.6c?
Google invariant mass and relativistic mass.
methods
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
