What is the weight of the beam?
  • Thread starter Thread starter looi76
    Beam Weight
To determine the weight of the beam, apply the principle of the lever, which states that the moments around the pivot must balance. A force of 300N is applied to hold the beam horizontally, indicating that the beam is in equilibrium. Key considerations include identifying the forces acting on the beam and their points of application, as well as calculating the torque they exert about the pivot point. Since the beam is in equilibrium, the net torque must equal zero. This analysis will lead to the calculation of the beam's weight.
looi76
A long uniform beam is pivoted at one end. A force of 300N is applied to hold the beam horizontally.
http://img182.imageshack.us/img182/4219/11062008vt2.png
Don't know which question to use... need help!
Ask yourself:
(1) What forces act on the beam? Where do they act?
(2) What torque do they exert about the pivot point?
(3) Since the beam is in equilibrium, what must be the net torque?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
