What Is the Work Function of Millikan's Hypothetical Metal?
The discussion revolves around calculating the work function of a hypothetical metal based on Millikan's observations of the photoelectric effect. Given the maximum kinetic energies of 0.535 eV and 2.52 eV for different wavelengths of light, participants explore the relationship between energy, frequency, and the work function. The stopping potential (Vo) is identified as crucial for determining the work function, with suggestions to use alternative forms of the photoelectric equation for clarity. The conversation highlights the need for a clear understanding of how to derive Vo from the maximum kinetic energy. Ultimately, the participants seek guidance on completing the calculation of the work function.
TJDF
The American physicist Robert A. Millikan (1868-1953) won the 1923 Nobel Prize in physics, in part for his work on the photoelectric effect. Assume that Millikan observed for a hypothetical metal a maximum kinetic energy of 0.535 eV when electrons were ejected with 431.7 nm light. When light of 258.6 nm was used, he observed a maximum kinetic energy of 2.52 eV. Using these results, calculate the work function, W0, for the metal, without knowing the value for Planck's constant.
Vo = [(h/e)*f]-(θ/e)
where θ is the work function.
Frequency 1 (using wavelength 1) = 6.94927e14 Hz
Frequency 2 (using wavelength 2) = 1.1601e15 Hz
Delta Frequency = 4.65173e14
Energy 1 (using eV1) =8.571644e-20 J
Energy 2 (using eV2) =4.0375e-19 J
Delta Energy = 3.18032e-19
thus, Delta Energy over Delta Frequency gives me my experimental h...
h = 6.83685e-34 Js
That's all fine and good... but
I have NO idea how to solve for the work function.
Greatly appreciate a reply, this is my last question of the day.
Hmmm... still no luck on this one yet. ideas?
some progress...
so e = 1.60e-19 C
f will equal 0... so...
Vo = θ/e ; θ = e*Vo = (1.60e-19J)*( ? V)
hmmmm... how to figure out Vo?
Hi TJDF,
TJDF said:
some progress...
so e = 1.60e-19 C
Vo is the stopping potential, which is the potential required to stop even those electrons with the maximum kinetic energy. In that case, the maximum kinetic energy is being converted completely into potential energy. Do you see how to calculate Vo?
(You might also find some other forms of the photoelectric effect equation that have the maximum kinetic energy explicitly, instead of the stopping potential; those forms would be more straightforward for this problem.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
