What is the Young's Modulus of Panzani Spaghetti?
The discussion focuses on obtaining the Young's modulus of Panzani spaghetti for an IB Physics extended essay. A participant mentions a study by G.V. Guinea et al. that reports an elastic modulus of 5 GPa for dry spaghetti made from durum wheat semolina, based on tensile tests. The inquiry specifies a preference for dry spaghetti data. The shared article also touches on pasta fracture morphology, which could be relevant for culinary interests. This information could aid in experimental data collection for the original inquiry.
simon.m
I am working on my extended essay in IB Physics and would like to have some experimental data. More specifically I need Young's modulus of spaghetti (Panzani -- if possible :). In case you've done a lab or some other research where you calculated this value, please send me a link (or just any other info you may have). thx
Simon
dry or wet?
:) good question.
DRY, please!
... came across this a while ago :
G.V. Guinea et al, Brittle failure of dry spaghetti, Engineering Failure Analysis, 11, 2004, 705-714.
... in it for durum wheat semolina, base material for spaghetti, they among other stuff do tensile tests and arrive at an elastic modulus of 5 GPa. I first picked the article since was interested about pasta fracture morphology, perhaps to improve my cooking . :biggrin:
Phys. Rev. Lett. 95 095505
This might be of interest to you.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
