Undergrad What kind of differential does the small Greek delta letter represent?
The small Greek delta letter δ represents a differential element for parameters that are not well-defined functions, often used in thermodynamics for quantities like heat and work. In contrast, Sabina Hossenfelder suggests it can also denote a differential function with a path as its input variable, linking it to calculus of variations. The symbol's meaning can vary significantly depending on the context in which it is used. An example from Lie theory illustrates that δ signifies "something small" in specific mathematical frameworks. Understanding these nuances is crucial for accurate interpretation in physics and mathematics.
swampwiz
δ
I had always thought that it represents a differential element for a parameter that it is not supposed to be a well-defined function - e.g., for a differential or heat or work in thermodynamics - as opposed to a regular Latin d, which is supposed to be such a well-defined function. However, Sabina Hossenfelder says here that it means a differential that is meant to be a function whose input variable is a path, which sounds like something out of calculus of variations.
And I always thought that ##\delta## was Dirac's delta :smile:
The same symbol can have different meaning in different contexts.
Likes fresh_42 and topsquark
swampwiz said:
δ
Here is an example that fits into the context:
https://www.physicsforums.com/insights/when-lie-groups-became-physics/
It is basically how it was used in:
A. Cohen, An Introduction to Lie Theory of One-Parameter Groups, Baltimore 1911
At least, it shows that "something small" is the answer in the given context.
  • · Replies 85 ·
34K
  • · Replies 0 ·
