I What Milky Way stars could go supernova to < +3 at any time?
The discussion focuses on which Milky Way stars could potentially go supernova and reach an apparent magnitude of +3 or brighter at their peak brightness. While Betelgeuse is often mentioned, other candidates like Sher 25 and Eta Carinae are highlighted as likely to explode soon. The conversation also touches on the capabilities of observatories to respond quickly to such events, noting that factors like distance and equipment availability play significant roles. Additionally, the Supernova Early Warning System is mentioned as a tool that could provide advance notice of a supernova, as demonstrated by the neutrinos detected from SN1987A. Overall, the thread emphasizes the uncertainty surrounding supernova predictions and the vast number of potential progenitor stars.
swampwiz
(I use +3 as the cutoff as that seems to be the limit of easily visible stars.) Yes, I know that Betelgeuse could go up in a < -10 blaze of glory, but I wonder what other ones are out there.
On a side note, how fast could the big observatories move to it to observe it? And how quickly would it be noticed at all?
Astronomy news on Phys.org
physicshelp21 said:
There are many stars that are visible to the naked eye and have an apparent magnitude of +3 or brighter. Some examples include Sirius, Canopus, Alpha Centauri A and B, Vega, Capella, Arcturus, and Rigel. There are also many other stars that are visible to the naked eye but have an apparent magnitude fainter than +3.
Regarding your second question, the speed at which observatories could move to observe Betelgeuse depends on a number of factors, including the distance to the star, the location of the observatories, and the availability of suitable telescopes and other equipment. Betelgeuse is located approximately 642.5 light-years from Earth, which means that it would take a very long time for a spacecraft or other astronomical observatory to travel there.
I hope it helped.
I meant what stars could go as bright as +3 at the peak of their supernova, not current stars.
This weird answer sounds like it was generated by a bot.
Some people think that's funny.
You're not going to get a list.
First, your magnitude is not constraining. SN1987a wasn't even in our galaxy and it was brighter than 3.
Next, there are thousands upon thousands of stars who are likely progenitors. If we get on average one SN every 30 years and could tell within 30,000 years when one was nearing the end (and we can't) that would be a thousand stars. Of these many thousands of stars, most don't have names, just catalog numbers, and some are obscured by dust and gas.
You want some possibilities: Sher 25 and Eta Carinae are likely to go "soon".
https://snews2.org/
The Super Nova Early Warning System is designed to give electromagnetic telescopes a warning ahead of the supernova's light.
The principle was first demonstrated when neutrinos from supernova SN1987a preceded that explosion's light by two to three hours.
https://en.wikipedia.org/wiki/SN_1987A
Thanks,
Cerenkov.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
