MHB What percentage of the class scored between a 67% and an 83%
  • Thread starter Thread starter anyalong18
    Class
The exam scores for a difficult math test had a mean of 75% and a standard deviation of 8%. To find the percentage of students scoring between 67% and 83%, the scores correspond to z-scores of -1 and 1, respectively. These scores are one standard deviation from the mean in a normal distribution. By consulting the standard normal distribution table, the area between these z-scores can be determined, which represents the percentage of students within that range. The final calculation shows that approximately 68% of the class scored between 67% and 83%.
anyalong18
The exam scores for a particularly difficult math test had a mean score of 75% with a standard deviation of 8%. Approximately what percentage of the class scored between a 67% and an 83%.
Mathematics news on Phys.org
Assuming this is a normal distribution, these scores are each within one standard deviation from the mean, so the percentage is...?
I'm sure you know, if you are taking a course in which a question like this is asked, that you do NOT "calculate" the answer but look it up in a table of the "Standard Normal Distributio". Surely there must be one in your textbook but there are also several on line.
There is a good one at normal distribution table - Bing images
The standard normal distribution has mean 0 and standard deviation 1. With mean 75 and standard distribution 8, (x- 75)/8 corresponds to x.
So a score of 67 corresponds to (67- 75)/8=-8/8= -1 and a score of 83 corresponds to (83- 75)/8= 8/8= 1.
Those scores are, as Prove It said, one standard deviation off the mean. In the table, you look up z= 1 and, because of the symmetry, the "z-score" for -1 is the negative of that. x- (-x)= 2x so the probability is just 2 times the value you looked up.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
