What should be the power rating of the StepDown Transformer?
To safely use a US 110v antique chemical photobooth in a 220v country, a step-down transformer is necessary, ideally rated with a power demand plus a safety margin of 2:1. The term "VAL" in the circuit diagram refers to voltage value, with no current restrictions specified. Users should verify the output voltage with a multimeter before use, especially if the device is heavy, indicating it may handle higher loads. A clamp-on amp meter can measure current without cutting cables, and the circuit breaker or fuse rating of the current setup can provide additional safety insights. Understanding the power demand of the antique device is crucial for selecting the appropriate transformer.
Yam
Dear Forum Members,
I imported an electrical equipment from the US which uses 110v, my country used 220v and as such i need to pirchase a step down transformer.
The equipment is a piece of antique and doesn't come with much instructions. I could only get a circuit diagram and i am puzzled by what is VAL. Could anyone help me out?
As i saw your circuit its a one step -down transformer such that if you input 240 volts it can give an output of 115 volts - naturally the number of turns in the primary and secondary have been adjusted to give this output . i could only that VAL. refers to the value of the voltage -there is no restriction on current given - but before using it one should check by a multimeter the real output voltage with a main line input-just to be on safe side- if the equipment is very heavy say 10 kg or so then it may be rugged one and can withstand higher load-that is my guess!
Any answer to your question must begin with the power demand of your as antique device, plus a safety margin such as 2:1.
If you don't know how much power your antique device uses, your question can't be answered.
I can't seem to find any information of the power demand of this equipment, its actually a large antique chemical photobooth.
Ill do my best to search for the power demand
After getting a multimeter, is there anyway i can measure the current without cutting the electrical cables?
I have the circuit diagram of the entire system, would it help if i uploaded it? not too sure if i am allowed to do so or not too.
Yes, a clamp on type amp meter can measure current without breaking the circuit. Just make sure that it is clamped on only one of the two conductors to the wall plug.
A circuit diagram will probably not help.
If it is plugged in and working now, what is the fuse/circuit breaker rating of the circuit it is plugged in to?
Likes drvrm
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
