What should hidden variables explain?
In summary: Yes, I accept that Bell can suppose that a spin can have values along different directions even if QM says that it is not possible.
naima
54
It is often said that the Bell's theorem precludes local hidden variables. From a "modern" point of view one should never deduce conclusions from the existence of outputs in non commutative measurements.
It seems that the derivations of this theorem use such results.
Is there a proof which uses only the ##\lambda## in the case of possible measurements?
Hidden variables should allow to say that the moon is there when we are not looking at it.
More mathematically, hidden variables should allow us to show that quantum mechanics can be obtained from a theory whose state space is a simplex, as it is in classical probability.
Isn't decoherence allowing us for that?
I think that the usual proofs of Bell's theorem are dated. they were for those
who had doubts about QM. They thought that imposible measurements nevertheless had outputs. Assuming that the theorem tells them that this leads to the well known inequalities.
Time have changed. We cannot allow such assumptions to discard hiden variables.
1) Bell's theorem doesn't rule out all hidden variable theories, it only rules out local hidden variable theories.
2) What impossible measurements are you talking about? All Bell assumes on the experimental side, is that there are two apparatus that can measure the spin of the two particles!
Take for instance this good link written by DrChinese.
He writes:
"no matter which of the 8 scenarios which actually occur"
We know that with 2 particles we cannot measure a spin in 3 directions.
It is a prequantic idea.
If Bell's aim were to discard local hidden variables we cannot accept such arguments. Would you accept the use of absolute simultaneity in the proof?
He writes:
That's absurd. You're trying to defend hidden variables by denying them!
The whole point of hidden variables is that physical systems have properties and those properties have values, independent of the observer and whether s\he measures anything or not. If you don't like the assumption that we can talk about properties that can't be measured, then you actually don't like hidden variables!
And that's exactly what Bell's theorem is about! You seem to think that hidden variables are something different from this assumption and so you think if we put aside this assumption, we can retain hidden variables. But hidden variables are invented exactly for that purpose, to let people talk about properties of the physical systems independent of the observer, and Bell is showing that this assumption is incompatible with locality.
Also...where does absolute simultaneity play any role?
You are partly right.
I do not like these hidden variables that would assign values to unmeasured properties. But when t'Hooft is looking for a cellular deterministic automat, he starts with initial values to find the outcome in an actual measurement.
I also call these positions hidden variables because one cannot know all them in the universe. There is no copyright for "hidden variables"
Of course absolute simultaneity plays no role here. I am sure that you would reject a theorem (would you read it entirely) if it supposed it?
But you accept that Bell can suppose that a spin can have values along different directions even if QM says that it is not possible.
No. Decoherence does not solve the measurement problem, unless additional assumptions are added - that is pretty much the standard view. Thus for example, many-worlds tries to add the assumption that more than one outcome occurs.
I think Bell's theorem encompasses that too. So such models should be non-local. And if his approaches aren't much different from Stephen Wolfram's, I think this shouldn't be surprising that they give rise to non-local models.
So that was an analogy. OK, that depends but generally I won't be enthusiastic about it. I see what you're saying.
But this is very different. There are two things that you still don't understand.
1) QM doesn't say that a spin can't have values along different directions. This is obvious from the Stern-Gerlach experiment where you can decompose the beam of particles along any two perpendicular directions that you desire. But I suppose that's not what you mean. I think you wanted to say, that QM says a spin can't have components along directions along which no measurement is being done on it. But QM doesn't say that either! Before Bell, there was only the thought experiment presented by EPR, and an equivalent version by Bohm and Aharonov. It was supposed to demonstrate that QM is incomplete. It was Bell's theorem that clearly demonstrated what QM has to say about such thought experiments and what are the true implications of them!
2) Have you ever tried to prove that ##\sqrt{2}## is an irrational number? Its usually done using proof by contradiction, you assume something is true and then show that it leads to contradiction and so you conclude that the assumption was false and so you have proved that the negation of the assumption is true. What would you say if after such a proof, someone criticizes your proof by saying that your proof isn't correct because your assumption leads to contradiction and so you didn't have the right to make that assumption?! You see? That's what you're doing here! Bell assumes local hidden variables and shows that they lead to contradiction and so they can't be correct. So I really don't understand what it is that you're criticizing!
There can be alternate definitions of "hidden variables". (post 9)
Bell's proof is about the local hidden variables which assign values to unmeasured experiments.
Its the definition of hidden variables to assign values to unmeasured quantities. It doesn't matter whether they're local or non-local. Its just that, by Bell's theorem, local ones are in contradiction with QM.
And as far as I understand it, t'Hooft's approach is a hidden variable theory too!
Ok that is your de finition. Can you give me links from good authors or textbooks that agree with it?
I do not read that in wikipedia. They talk about underlying parameters which would give deterministic outcomes for each actual measurement.
I can't give any reference for that but that's pretty obvious.
One of the principles of QM is that the information that the wave-function of a quantum system gives you, is the maximum amount of information you can have about that system and there is simply nothing more to be known about it. And even when you have all there is to know about the quantum system, all you can predict is the probability distributions of values for different observables. This means that the maximum amount of information you can have about a quantum system, doesn't determine the values of its properties uniquely. That's what some people don't like, and the only way to change it in a way that you retain the power you had in classical physics where you could uniquely predict the value of any property you wanted(at least in principle), is to somehow distinguish between states that QM considers equivalent. And that can only be done by postulating that the information contained in the wave-function is not the maximum amount of information you can have about the system and there are some extra information that if we had access to, we could uniquely determine the values of different observables. Those extra information are called hidden variables. In fact if you don't use hidden variables in this way, they lose their meaning and there is no reason to have them in the theory. What else are they supposed to do?!
Anyway, I checked this paper by 't Hooft. It seems to me that he circumvents Bell's theorem by assuming superdeterminism, which means he assumes that the experimenters are not free to choose the settings on their measurement devices and this implies that because the settings on the devices are predetermined and so each device already "knows" what's going to happen to the other device, they can adjust themselves somehow that Bell's inequality is violated while still retaining both realism and locality!
Likes dlgoff
But you can't rule out Many-Worlds and other theories where the definition of "local hidden variables" is modified because it gives the same predictions as quantum theory (in the domain where we can currently test).
And Bell's theorem is still immensely useful today in certifying that quantum devices can't be simulated by using shared randomness. The customers may believe in quantum theory, but they don't have to trust the devices' manufacturers.
I did not think that this theorem was useful.Could you elaborate? thanks.
Naima, I see where you are coming from. I could entertain there being a distinction between an unmeasured quantity and a measured one. But a predisposition to a certain measured quantity would of itself be a quantity.
No problem. The fact that Bell tests depend only on measurement statistics and not where the statistics come from is the basis of device-independent quantum cryptography. Maximal violation of Bell-CHSH inquality also certifies that you have a singlet state and can be used to certify some quantum computation. These are in the section "Applications of quantum nonlocality" of this review article: http://arxiv.org/abs/1303.2849
Thank you for the link Truecrimson.
I read in page 3 that the locality property
##P(a,b,\lambda) = P(a,\lambda) P(b,\lambda) ## leads the Bell's inequalities without requiring that the same lambda give outputs for noncommuting observations.
I understand now why Shyan could not give me a reference with this property of hidden variables. (nobody here reacted)
Likes Truecrimson
Cough!
Any proof of Bell's theorem (or similar theorems) assumes that a local realistic model has the property of counterfactual definiteness, i.e, it should be possible to use the model to compute a predicted outcome of any hypothetical experiment for which the model applies, irrespective of whether the experiment is performed or not. In particular, it should be possible to use the model to predict outomes for say both of two possible detector settings for one and the same lambda, even if only one setting can be applied at a time in an actual experiment. There is actually nothing in the paper linked by Truecrimson that contradicts this.
Likes Truecrimson
It's not necessary to ASSUME that [itex]\lambda[/itex] determines the outcomes of all measurements, but that is a mathematical conclusion.
You might start assuming that
  • [itex]P_A(a,\lambda) = [/itex] the probability of Alice getting spin up, given that the hidden variable has value [itex]\lambda[/itex], and that the orientation of Alice's detector is [itex]a[/itex]
  • [itex]P_B(b,\lambda) = [/itex] the probability of Bob getting spin up, given that the hidden variable has value [itex]\lambda[/itex], and that the orientation of Bob's detector is [itex]b[/itex].
If we assume that every particle is detected, and that the spin is either spin-up or spin-down, then
  • [itex]1 - P_A(a,\lambda) = [/itex] the probability of Alice getting spin down, given that the hidden variable has value [itex]\lambda[/itex], and that the orientation of Alice's detector is [itex]a[/itex]
  • [itex]1 - P_B(b,\lambda) = [/itex] the probability of Bob getting spin down, given that the hidden variable has value [itex]\lambda[/itex], and that the orientation of Bob's detector is [itex]b[/itex].
But in the case of the anti-correlated spin-1/2 twin pairs, you know that: If Alice measures spin-up at angle [itex]a[/itex], then Bob will definitely not measure spin-down at that angle. So there is zero probability that they both measure spin-up at angle [itex]a[/itex]. That implies:
(1) [itex]P_A(a,\lambda) \cdot P_B(a, \lambda) = 0[/itex]
But also, if Alice measures spin-down, then Bob definitely will NOT measure spin-down. That implies:
(2) [itex] (1-P_A(a,\lambda)) \cdot (1 - P_B(a, \lambda)) = 0[/itex]
Together, (1) and (2) imply that
[itex]P_A(a,\lambda) = 0\ \&\ P_B(a,\lambda) = 1[/itex]
or [itex]P_A(a,\lambda) = 1\ \&\ P_B(a,\lambda) = 0[/itex]
That implies that the spin Alice measures for angle [itex]a[/itex] is completely determined by [itex]\lambda[/itex], and similarly for Bob.
Likes DrClaude, maline and Truecrimson
I'm also not sure why the paper I gave convinced you of that. Maybe it's the part where they say the hidden variables don't have to be constant throughout different runs? It's a random variable so its values can fluctuate, but it's still the same variable ## \lambda ## that influences the outcomes of noncommuting measurements.
I have a problem with my computer. I'll be back next week.
Of course, if the existence of absolute simultaneity would be derived from the assumptions as part of the proof.
As it is in this case with the "hidden variables".
The "hidden variables" are derived from the EPR principle of reality, and the observable fact that if Alice and Bob measure in the same direction, they get a 100% correlated result. The EPR principle: If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, there exists an element of physical reality corresponding to this physical quantity.
The aim is simply to get a meaningful, non-mystical description of reality. Some hidden variable theories have randomness, thus, do not propose any type of additional control, and even deterministic dBB theory assumes (derives) a quantum equilibrium which one cannot leave, and which gives the same uncertainty as QT. So, your picture of the hidden variable proponent is a strawman.
I never said such theories differ with QM in predictions. In dBB particles always have definite positions, but the randomness and other features that make its predictions indistinguishable from QM are given to it by other means!
My criticism was directed against your picture of the hidden variable proponent.
The hidden variable proponent wants to understand what happens. A very natural thing. To use some simple models of what could possible happen in reality is a standard way to reach this aim.
In general, I think it is not very good to speculate about the motives of those who prefer other choices. To demonstrate why, I can present a similar unfavorable picture of the "relativists". They observe that all such realistic models violate Einstein causality. This is something they are not ready to accept, and if there is a theorem which proves that every realistic model has these properties, all the worse for reality - he will give up realism, once it does not fit his relativistic belief. And, once there is no longer any reality outside, there is no longer any need to study realistic models which violate the "relativistic belief".
One can, then, extend this to comparisons of "relativists" with various religious believers. A strawman? I'm afraid to discuss this in Physics Forums would not be appropriate. (If you want, let's discuss this, say, at http://ilja-schmelzer.de/forum/.) But I hope you get the point that I, as a proponent of hidden variable theories, feel equally uncomfortable with such speculations about my motivation.
Likes maline
I have no idea what you're talking about!
I didn't like your speculation about "That's what some people don't like" from https://www.physicsforums.com/goto/post?id=5491731#post-5491731. It ended with "In fact if you don't use hidden variables in this way, they lose their meaning and there is no reason to have them in the theory. What else are they supposed to do?!", which I interpreted as an argument that your speculation about the motives of hidden variable proponents is the only possible one. So, it is a claim about what all proponents of hidden variables don't like.
I'm a proponent of hidden variable theories, and I do not care at all about what I'm supposed not to like. So I have objected. Sorry if I have completely misunderstood you.
  • #31
I have nothing against the possibility of hidden vatiables.
According to me everytime a measurement is DONE, a hidden variable would correspond to a set of datas from which an algorithm or procedure or map would give the outcome of the measurement.
It is not the idea that given these datas there is a map which give an output to any measurement.
There is also a big problem in the methodology used to discard hidden variables.
Take the paper written by DrChinese.
He shows very well how Bell uses non observed "observables".
Take the EPR experiment with two particles. At each shot the spin is measured along two different directions chosen into A B and C.
We begin with 3 counters (equal to zero) i call them AB BC and CA
if say the directions are C and A and the spins match i add 1 to CA else i add nothing.
I can consider at the end the mean value of AB + BC + CA: if there were N shots i divide their sum by N.
Let us now look at the way one can discard hidden variables:
We consider now that AB BC CA are observables having values at each shot. there are 8 possibility so DrChinese introduce a table wit 8 lines.Suppose that the directions are A and B and that the spins do not match. one is up and the other down. What about the spin along C? it will match with A or B. so we will add 1 to BC or CA. A each shot AB + BC +CA is increased. Of course here at the end we divide by 3N. the result is > 1/3
In the reality we can have sequences of three shots that do not match. and the observed meanvalue < 1/3 so we say that hidden variables are discarded.
How can we accept such biased methodology to derive anything?
Take the proof of Kochen theorem in the WIKI it also use such tableaux.
I thank DrChinese for the quality of his paper.
  • #32
In the reality we can have sequences of three shots that do not pair. and the observed meanvalue < 1/3 so we say that hidden variables are discarded.
If you mean http://drchinese.com/David/Bell_Theorem_Easy_Math.htm, it is fine, but has not prevented you from not understanding a central point: Namely the point that all three values A, B, C have to be predefined is not an arbitrary hidden variable assumption, but a conclusion, derived from the EPR argument. And that we do not reject hidden variables in general, but only those Einstein-local realistic theories, where we can use the EPR argument to derive that the results have to be predefined even if not measured.
Bell was at that time aware that there exists a hidden variable theory - de Broglie-Bohm theory - which gives all the quantum predictions. His aim was not at all to disprove hidden variables - he was at that time essentially the only proponent of dBB theory. It was to show that the attack against dBB theory that it needs a (hidden) preferred frame was unjustified, because every realistic interpretation needs a preferred frame. It was, I would guess, unimaginable at that time that people would be readily give up realism and causality and all this only to preserve the (metaphysical) idea that relativistic symmetry is fundamental.
  • #33
We find the words "local" and "locality" in the DrChinese paper but is there a locality argument in the way to fill the table.
We have a game with two possible results: 1 and 1/3.
Do we need an experiment to show that Nature with its possible 0 results is not like that?
  • #34
What is your question? Can you state it clearly?
Non of the things you say make sense to me!
  • #35
Read the sentences with a ? at the end!
Your "What is the question," is absurd but i understand that it looks like a question.
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
