What type of dielectric is used in an NP0 capacitor?
NP0 capacitors are made from C0G dielectric materials, which are classified as EIA Class I ceramics. These formulations typically include rare Earth oxides like neodymium and samarium, contributing to their stability. C0G (NP0) capacitors exhibit minimal capacitance change with temperature, rated at 0 ±30ppm/°C, and have negligible capacitance drift of less than ±0.05%. They also demonstrate excellent longevity with a typical capacitance change of less than ±0.1% over time. Overall, C0G (NP0) capacitors are recognized for their reliability and stability compared to other dielectric types.
sodoyle
TL;DR Summary
What type of ceramic is an NP0 capacitor made from? I know X7R is barium titanite, but I can't find NP0.
https://www.avx.com/products/ceramic-capacitors/surface-mount/c0g-np0-dielectric/
"C0G (NP0) is the most popular formulation of the “temperature-compensating,” EIA Class I ceramic materials. Modern C0G (NP0) formulations contain neodymium, samarium and other rare Earth oxides. C0G (NP0) ceramics offer one of the most stable capacitor dielectrics available. Capacitance change with temperature is 0 ±30ppm/°C which is less than ±0.3% C from -55°C to +125°C. Capacitance drift or hysteresis for C0G (NP0) ceramics is negligible at less than ±0.05% versus up to ±2% for films. Typical capacitance change with life is less than ±0.1% for C0G (NP0), one-fifth that shown by most other dielectrics."
Thanks, that's exactly what I was looking for. Even though C0G is a temperature coefficient, it's also interesting that they're have a lot flatter CV curve.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
