What Was the Initial Velocity of an Object That Traveled 120m in 5.60s?
To find the initial velocity of an object that traveled 120m in 5.60s with a final velocity of 15.0m/s, the relevant equations include v = d/t and a = (v2 - v1) / (t2 - t1). The discussion raises the question of whether acceleration needs to be considered in the calculations. The user is unsure if the object started from rest and is seeking clarification on their approach. Ultimately, the book indicates that the initial velocity is 28 m/s.
StupidGenius
What was the initial velocity of an object that moved 120m in 5.60s, reaching a final velocity of 15.0m/s in that time?
v=d/t
a=v2-v1/t2-t1
3. The Attempt at a Solution
I was wondering is there an acceleration that I'm missing here? or am i just off?
I've been using this eq. v1=v2-a(changeintime)
Someone help :(
was the object at rest?
The book's answer is 28 m/s =S
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
