What's the air temperature when Δd=250m
  • Thread starter Thread starter crystalspark
    Air Temperature
To calculate the air temperature based on the echo from a cliff, the distance of 250 m is divided by 2 to find the one-way distance of 125 m. The speed of sound is determined using the time of 1.5 seconds, resulting in a calculated speed of 83.33 m/s. This speed is then set equal to the equation for the speed of sound, v = 331 m/s + (0.59 m/s/°C)T, to solve for temperature T. The discussion raises questions about the distance traveled by the sound wave and the reasoning behind using half the distance. Understanding these calculations is essential for determining the air temperature accurately.
crystalspark
A hunter wanted to know the air temperature. The echo from a nearby cliff returned 1.5 s after he fired his riffle. If the cliff is 250 m away, how do you calculate the air temperature?
v=331 m/s + (0.59 m/s/c˚)T niSinθi=nRSinθR x=Δd/2 These eq'ns might be useful
x=250 m/2 = 125
v=125 m/1.5s = 83.33 m/s
83.33 m/s = 331 m/s + (0.59 m/s/c˚)T
why you used x = 125??
what is the distance traveled by sound wave in the whole process?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
