What's the difference between CTT and TTA?
  • Thread starter Thread starter Str1pe
    Difference
CTT and TTA both code for leucine, meaning there is no direct difference in DNA regarding leucine production. However, the distinction between these codons could have implications beyond leucine synthesis. While most DNA-binding proteins interact with regulatory regions rather than coding sequences, minor variations can influence regulatory elements. Synonymous mutations, which do not change the amino acid sequence, typically have no effect but can occasionally impact protein function. These mutations may alter mRNA structure, potentially affecting protein folding by causing ribosomal pausing during translation. Additionally, changes in codons corresponding to rare tRNAs can influence translational pausing and protein folding efficiency. Overall, while CTT and TTA serve the same purpose in coding for leucine, their differences may have nuanced effects on gene regulation and protein synthesis.
Str1pe
Hopefully this is a pretty simple question, but I'm more a rock guy... :redface:
CTT and TTA can both be used to make leucine. So to make leucine there is no difference to an organism's DNA whether it has CTT or TTA in the right place. But might the difference between CTT and TTA have other effects not related to the production of leucine?
Biology news on Phys.org
No, no difference. I suppose, it could make a difference if a regulatory element bound there as the "shape" of small segment would be different. But most DNA binding proteins don't bind in coding regions of genes. Rather to specific effector regions outside the coding region.
Minor clarification note, you've listed the non-coding strand of DNA.
The coding strand would be GAA or AAT. The mRNA would be CUU or UUA.
Probably going way beyond the scope of your question, but interesting nonetheless, is that since CUU/CUC/CUA all code for Leu, then they probably use the same tRNA.
tRNA can use a 5th base, inosine. Which when in the 5' (five-prime) position of the anticodon can recognize a U, C or A. So rather than having 3 different tRNAs you can have GAI, which would pair with all three. G and U can also form "wobble" base pairs with C or U and A or G, respectively, also reducing the number of tRNAs needed to recognize a codon.
Most of the time, mutations that change the nucleic acid sequence but do not change the amino acid identity (called synonymous mutations) do not have any effect on an organism. There are, however, special cases where synonymous mutations do have an effect.
First, as bobze noted, synonymous mutations can change regulatory elements such as splice sites, which can change a protein's structure and function. There is also new research suggesting that synonymous mutations can affect protein folding, however. One mechanism may be through altering mRNA structure. If the mRNA folds back on itself to form a hairpin structure, the hairpin could impede the ribosome from translating the mRNA, causing the ribosome to pause. This pausing during protein synthesis might be useful to give the protein time to fold correctly before other segments of the protein are translated that might interfere with folding had a pause not occured. Synonymous mutations which alter mRNA structure may be able to alter the efficiency of protein folding in this way.
Another way the cell can pause protein synthesis is by encountering a codon that corresponds to a rare tRNA. By mutating a codon for a rare tRNA to a more abundant tRNA or vice versa, synonymous mutations can alter translational pausing and may be able to affect protein folding.
Hmmm ... OK. Sounds like I have my work cut out for me. Thanks, fellas. :)
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
