What's the difference between Recursion & Reduction in terms of Integration?
LearninDaMath
My book talks about the "reduction formulas" for evaluating trigonometric integrals by parts. However, is this the same thing as "recursive" formulas for integration by parts, a term which is not mentioned in my calculus book?
Recursive means something defined in terms of itself, but with a different conditions. For example, factorial: n! = (n - 1)!n.
It is not entirely clear what in you book is called "reduction formulas", but if that means, for example, something with degrees defined in terms of something similar with smaller degrees, then this could be equally called recursive formulas.
Yes, they are talking about degrees defined in terms of something similar with smaller degrees when mentioning "reduction formulas." Thanks for clarifying and confirming they are different words meaning the same thing in this case.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
10K
