What's the force moving electrons against E within copper-zinc
In summary: The first article explains why electrons move within zinc-copper interface by introducing energy required for the most energetic electron to escape from a metal (so-called work function). It is said that the most energetic electrons in zinc have more energy than those in copper. And because electrons in zinc love to stay in a low energy state, they flow from zinc to copper.
Tekk
I have a piece of copper in static condition. Since copper is a conductor, within the copper there is no electric field. Strange comes when I bring this copper in contact with a piece of zinc: in a tiny interval of time, certain amount of electrons would flow from copper to zinc.
I suspect that during this interval, electric field would be created and in order to move electrons against this field, there must be a non-electrical force. So the question is: what's this force?
I have searched this topic and answer are chemical force/potential etc. I would be very appreciated if anyone could give a force which the Newton 3rd Law could apply to, such as the Coulomb force, gravitational force.
I offer no answer, but I think you've asked an excellent and quite fundamental question.
Drakkith said:
The first article explains why electrons move within zinc-copper interface by introducing energy required for the most energetic electron to escape from a metal (so-called work function). It is said that the most energetic electrons in zinc have more energy than those in copper. And because electrons in zinc love to stay in a low energy state, they flow from zinc to copper. Is my understanding correct?
Besides, the article has not discussed what the energy is and what force is applied when electrons flow from zinc to copper. In the second article you have cited, the energy is called chemical potential. Is it a scalar function? Can I take the gradient of that chemical potential? If yes, does the gradient make sense as some kind of force?
FAQ: What's the force moving electrons against E within copper-zinc
What is the force that moves electrons within copper-zinc?
The force that moves electrons within copper-zinc is known as the electric force. This force is created by the difference in electric potential between two points, known as an electric field. In the case of copper-zinc, this electric field is created by the difference in electric potential between the copper and zinc atoms.
How do electrons move within copper-zinc?
Electrons move within copper-zinc due to the presence of an electric field. This electric field causes the electrons to experience a force, known as the electric force, which drives them in a particular direction. In the case of copper-zinc, the electric force moves the electrons from the copper atoms to the zinc atoms, creating an electric current.
What is E in the context of copper-zinc?
In the context of copper-zinc, E refers to the electric potential difference or electric field strength. This is the measure of the strength of the electric field between two points, such as the copper and zinc atoms in copper-zinc. It is typically measured in volts per meter (V/m).
How does the force moving electrons against E within copper-zinc impact its properties?
The force moving electrons against E within copper-zinc is what allows it to conduct electricity. Without this force, the electrons would not move from the copper to the zinc atoms, and there would be no electric current. This property of conducting electricity makes copper-zinc useful in various electronic applications.
Can the force moving electrons against E within copper-zinc be manipulated?
Yes, the force moving electrons against E within copper-zinc can be manipulated by changing the electric potential difference or electric field strength. This can be done by applying an external voltage or changing the distance between the copper and zinc atoms. This manipulation of the electric force is the basis of many electronic devices and circuits.
