[C++] What's wrong with my program?
  • C/C++
  • Thread starter Robin04
  • Tags
    Program
In summary, the programmer is trying to determine the problem with their code, but ishaving no success. They have included all of the relevant information in the summary, so someone else can try to find theproblem.
Robin04
260
Hi,
I made a small program that simulates the motion of a body attached to an ideal spring and released from a horizontal position. Some more info here (especially #1 and #3): https://www.physicsforums.com/threads/equations-of-motion-unsolvable-with-elementary-method.827826/
I've been thinking a lot, I've already checked several times my equations and my code but I don't know what's wrong. The body just flies away to the other side of the Sun. :D
Do you have any idea what's the problem with my code?
Code:
#include <iostream>
#include <math.h>
#include <fstream>
using namespace std;
int main()
    float    x = 0.0f, y = 0.0f,
            v_x = 0.0f, v_y = 0.0f,
            a_x = 0.0f, a_y = 0.0f,
            D = 0.0f, L = 0.0f, m = 0.0f,
            dt = 0.0f, T = 0.0f, t = 0.0f, alpha = 0.0f, F = 0.0f;
    ofstream File;
    cout << "D = ";
    cin >> D;
    cout << "L = ";
    cin >> L;
    cout << "m = ";
    cin >> m;
    cout << "dt = ";
    cin >> dt;
    cout << "T = ";
    cin >> T;
    File.open("Coordinates.txt", ios::out);
    File << "D = " << D << "\tL = " << L << "\tm = " << m << "\tdt = " << dt << "\tT = " << T << endl;
    x = L;  // The pendulum starts from a horizontal position; y = 0
    while (t <= T)
        if (y != 0)
            alpha = atan2(x, y); //avoiding dividing by 0
        else
            alpha = 3.1415f / 2.0f; //if y = 0, than the angle is 90 degrees
        F = D*(hypotf(x, y) - L); //calculating the spring force: D * dl = D * (sqrt(x^2 + y^2) - L)
        a_x = F / m * sin(alpha); //calculating the components of the acceleration
        a_y = 9.81f - F / m * cos(alpha);
        cout << "Alpha = " << alpha*180/3.1415f << endl; //These are for trouble shooting to see what values go wrong, and as everything depends on everything this brought no help
        cout << "dl = " << hypot(x, y) << endl;
        cout << "F = " << F << endl;
        cout << "a_x = " << a_x << endl;
        cout << "a_y = " << a_y << endl;
        v_x += (a_x * dt); //velocities
        v_y += (a_y * dt);
        cout << "v_y = " << v_x << endl;
        x += (0.5f * a_x * pow(dt, 2) + v_x * dt); //updating the positions
        y += (0.5f * a_y * pow(dt, 2) + v_y * dt);
        cout << "t = " << t << "\tx = " << x << "\ty = " << y << endl;
        File << t << "\t" << x << "\t" << y << endl;
        t += dt;
    File.close();
    system("pause");
    return 0;
Technology news on Phys.org
Have you worked out the problem on a sheet of paper with columns for x, y, vx, vy, ax, ay ...?
From there you can see where things go astray.
Perhaps the order of your equations matters like try:
new x= old ax and vx used
new y= old ay and vy used
new vx= old ax used
new vy= old ay used
new ax= ...
new ay= ...
These are the equation I used.
  • Spring_Pendulum_Sim.docx
dt = 0? Try dt = 0.01; // time step
That's just an initial value. It's my habit to set every variable to 0 in order to avoid using them without value (in case I forgot to set them). The actual dt the program uses comes from an input at the beginning of the program.
Sorry, I didn't notice the initialization of dt.
1) It sounds like the sign of force is not correct if it flies off to infinity.
2) You might want to put some damping in your equations.
3) I see that you omitted gravity from your forces. Was that intentional?
Yes, I already thought about that and tried it with the opposite direction but it didn't work. By the way according to the equations in the doc, the signs are correct.
How do you mean damping?
It's there in the a_y. It start's by 9.81f -...
Aside: Yes, I am being mean and nasty. Please do not take it personally. You asked what's wrong with your code. I'm treating your code as if you had asked me to peer-review it. I'm mean and nasty in peer reviews. I don't pick at the person, but I definitely do pick at the code they wrote. I want exactly the same (actually, more so) in return. I want other people to be extremely mean and extremely nasty when it comes to reviewing the code that I myself have written.
Robin04 said:
Code:
The above lines of code are the immediate source of your problem. You have gravity plus a spring in the y-component (which is fine), but you have an anti-spring in the x-component (which is anything but fine). You have a sign error in the calculation of a_x. The immediate fix is to make that x-coordinate anti-spring force into a spring force by negating the sign: a_x = -F / m * sin(alpha) rather than a_x = F / m * sin(alpha).
However, (or perhaps However ), That is not the end of your problems. Why do you have that unneeded protection against y == 0 in your calculation of alpha =atan2(x, y)? For that matter, why are you using this construct at all? For that matter, why are you using alpha, period? (It's not needed.) Why are you using float rather than double? And (this is a bit more advanced), why are you using symplectic Euler integration?Your basic problems will disappear if you fix that one line (change a_x = F / m * sin(alpha) to a_x = - F / m * sin(alpha).
With regard to your deeper problems: I'll get to that in a couple of hours or so. My dogs (see my avatar) haven't had their long, long walk for six days. The weather here has cooled from nasty, nasty hot&humid to just mildly hot & mildly humid. My puppies need their long, long walk, and so do I.
Likes Robin04
Ok. Check the signs of force, signs of acceleration, change of velocity, rate of change of position, in that order. If it is not returning back, the first one that is wrong will tell you where the problem is.
In motion through air or a fluid, the velocity creates an opposing force that is proportional to velocity squared. Anything that is not in outer space sees some resistance to motion (friction, air, fluid, etc.)
Sorry. I missed that.
PS. I can't argue with D.H.s comments, but all-in-all your code is a lot better than a lot of code I see. The variable names make sense. There are comments (could be more obvious to divide sections. Like a top level outline.). It is logically organized .
Likes Robin04
That's not a problem at all. In fact, I completely agree with you. I can learn the most from straightforward opinions.
I tried it but it didn't work. The body still flies to space. Actually I don't really understand why I have a sign error. I checked my equations several times and they seem fine to me, but there has to be something that I miss. I uploaded the equations in #3.
I accidentally left it there. In an earlier version I had problems with the y coordinates, the loop started from y = 0.
My reason was that it was simpler to just copy the equations to the code and thus it's easier to check for any errors. By the way how can I determine the components of the force without knowing the angle between the vector and an axis?
I haven't programmed for a long time and I forgot some things. I corrected them. :)
As I'm a high school student I often don't know what I'm exactly doing, I just do what makes the most sense to me, or what I've been taught. But this fact doesn't mean that I don't even want to know what I"m doing. :D What method do you think would be the most accurate?
Have fun for me too. Here we still have 38 degrees. :P :D
I accidentally left out a cos alpha in the y direction forces, but the accelerations were correct. I uploaded the new doc.
Yes, I thought about putting air resistance into the calculations but first I would like to solve this problem. :)
You can format your fields in the file to look nicer with setw() and setprecision(), and to make it easier to add or delete fields separate the output variables.
File << setw(width) << t;
File << setw(width+5) << setprecision(3) << alpha; // here is an added output variable
File << setw(width+5) << setprecision(3) << x; // one way to change the width by adding a constant value
File << setw(width+5) << setprecision(3) << y;
File << endl;
Add the line
const int width = 6; // field width - change the value as desired.
somewhere top of the code. Below the main(), or the initializtion would be OK.
Likes Robin04
Also, try setting D to 0 and see what your results are.
With no spring constant acting the mass should fall in only the y-direction.
Note that the values of computed y-position should come out following the equation y = 0.5 a t2 + v0 t + y0.
At a time of t=0, that should be, with a = 9.81, a y-position of 4.91.
Does it?
Likes Robin04
File << endl;
Add the line
Thank you very much. That's a very useful tool. :)
In addition, you can try the following:
File << setiosflags(ios::fixed);
File << setw(width+2) << setprecision(3) << alpha;
File << endl;
Include file is,
#include <iomanip> // std::setiosflags
Likes Robin04
Does it?
I tried it, matched the data with my own calculations and they didn't agree. I realized that in this order in the first loop the program already calculates with initial velocities, which is not correct. So I rearranged the order of equations starting by calculating the positions, then the velocities and finally the accelerations and it worked, but only with D = 0. If I use this with D > 0 then the first loop will also be a free fall which is not the case (of course it's really close because at t=0 the spring is unloaded). But the flying to the Sun still happens. :D
Regarding your equations, I, for one, am not going to open a .docx file posted by an unknown person. Doing so is a recipe for a massive viral infection. Nothing against you personally, but I don't know you, so I can't trust you. This site uses MathJax to implement LaTeX. For example, ##F = -D(r - L)##. Using LaTeX is the recommended practice at this site (and many others) for representing equations.
To see that you indeed do have a sign error, suppose the initial state is x=2L, y=0. Your code has the spring force away from rather than toward the center.
You don't need to find ##\alpha## to compute the acceleration:
Code:
r = hypot(x, y);
a = D/m*r*(1.0-L/r);
a_x = -x/r * a;
a_y = -y/r * a + 9.81;
Note that the multiplication and division by r can be factored out, resulting in the simpler form
Code:
r = hypot(x, y);
a_factor = D/m*(1.0-L/r);
a_x = -x * a_factor;
a_y = -y * a_factor + 9.81;
Another problem with your code is the manner in which you update the state (position and velocity). You are using
Code:
v_x += a_x * dt;
v_y += a_y * dt;
x += 0.5f * a_x * pow(dt, 2) + v_x * dt;
y += 0.5f * a_y * pow(dt, 2) + v_y * dt;
This is incorrect. I'll give a few simple examples of how to perform this numerical integration.
1. Basic Euler method.
A very simple way to integrate a first order ordinary differential equation, ##\frac{dx}{dt} = f(x,t)## is via Euler's method:
Code:
x += f(x,t)*dt;
Yours is a second order differential equation. Any nth order ordinary differential equation can be re-expressed as a first order ordinary differential equation by adding extra states. In this case, the extra states are the x and y components of velocity:
$$\frac {d}{dt} \left(\begin{matrix} x\\y\\v_x\\v_y\end{matrix}\right) =
\left(\begin{matrix} v_x\\v_y\\-D/m (1-\frac L r) x\\-D/m (1-\frac L r) y + 9.81\end{matrix}\right)$$
This leads to the following code:
Code:
while (not done) {
    // Calculate a_x and a_y as above
    x += v_x * dt;
    y += v_y * dt;
    v_x += a_x * dt;
    v_y += a_y * dt;
While you should never use the basic Euler method, you should understand how it works.1. Symplectic Euler method.
One problem with using the basic Euler method on a second order ODE is that this technique does not conserve energy. Simply switching the order in which position and velocity are updated comes close to conserving energy:
Code:
while (not done) {
    v_x += a_x * dt;
    v_y += a_y * dt;
    x += v_x * dt;
    y += v_y * dt;
I'm not going to go into the mathematics that makes this simple switch a vast improvement over the basic Euler method.
2. Leapfrog.
One problem with *any* Euler method is that they are rather inaccurate. The error is proportional to $\Delta t$. You need to decrease the step size to improve accuracy, but decreasing the step size runs into numerical representation issues. (For example, try adding 1.0 + 1e-16 on your computer. The result will be exactly 1.0). A slight change yields a technique that is accurate to second order (error is proportional to $\Delta t^2$), the leapfrog technique:
Code:
// Calculate accelerations based on initial position, e.g., a_x = 0.0, a_y = 9.81.
dv_x = 0.5*a_x * dt;
dv_y = 0.5*a_y * dt;
while (not done) {
    v_x += dv_x;
    v_y += dv_y;
    x += (v_x + dv_x * dt) * dt;
    y += (v_x + dv_y * dt) * dt;
    // Calculate acceleration as above, using the end-of-interval x and y
    v_x += dv_x;
    v_y += dv_y;
Likes Robin04
Thank you very much for your answer. We have a power cut due to yesterday's storm. When the electricity comes back I'll try your suggested modifications and write back how they worked or if everything is clear.
Related to [C++] What's wrong with my program?
1. Why am I getting an error when I try to compile my C++ program?
There could be multiple reasons for this. Some common errors include syntax errors, missing or incorrect header files, or using a variable that has not been declared. Check your code carefully for any mistakes and make sure all necessary libraries and variables are included.
2. Why does my program crash or freeze when I run it?
This could be due to a variety of reasons, including memory leaks, infinite loops, or accessing out-of-bounds memory. Use debugging tools and techniques to help identify the source of the problem. Make sure to free up any allocated memory and check for errors in your loops and memory access.
3. How can I improve the efficiency of my C++ program?
There are several ways to improve the efficiency of your program, including optimizing algorithms, using efficient data structures, and minimizing unnecessary operations. Additionally, profiling tools can help identify areas of your code that may be causing performance issues.
4. Why is my C++ program not producing the expected output?
This could be due to logical errors in your code, incorrect input, or unexpected behavior of functions or libraries. Use debugging tools and techniques to step through your code and identify any mistakes. Make sure to also check your input and ensure it aligns with the expected output.
5. How can I make my C++ program more user-friendly?
You can make your program more user-friendly by implementing features such as error handling, input validation, and user prompts and messages. Additionally, consider organizing your code into functions and adding comments to make it easier for others to understand and use.
