- #36
Danger
- 253
Okay, I'm at work now. Pardon the delay... there were things to do when I got here--damned customers .
Anyhow, the major unique thing about it was the engine itself. All that I knew when I bought it was that it went like stink. Going by the VIN, it was the hi-perf 440. (The options were the standard or the Commando.) That indicated the 4-barrel carb, 10:1 compression, and 295 hp. (It's a GTX, by the way, but that package deals with suspension, brakes and cooling.) The factory redline was 5,500 rpm, but it didn't really start making power until 5,000. My rule was that the valves floated at 6,500 so I shifted at 6,400. It's an A-833 4 gear tranny with the long-throw Hurst pistol grip shifter, going into a 3.23:1 Dana 60. If I were going balls to the wall, I shifted to 2nd at 65 mph, third at 85, and 4th at 115--and 4th is a .73:1 overdrive. Top end was 160 mph. The estimated hp by performance (never dynoed it) was about 390.
440's don't particularly like to oil the #4 rod bearing for some reason, and the damned thing spun out on me whilst on vacation. The piston collapsed and took the bore with it. Hence the rebuild. When we took it apart, it surprised the hell out of us to find that it had 6 10:1 pistons and 2 8:1's. Also 6 4-barrel rods and 2 Commando ones. The odd rods were not linked to the off-spec pistons. The only explanation that I can think of is that it was the builder's way of balancing the motor. If so, it worked; the thing ran like a turbine at 6,000+ rpm.
And as for the paint job, Cyrus, it's getting the same one that's on my pool cue. If I can get it to show up properly, I'll post a pic. Starting at the front, it fog-fades from emerald green through teal, deep royal purple, and finally black.
edit: I just saw your post, Woolie; you sneaked it in while I was typing mine. As you've probably foreseen, my response is .
2nd edit: Cyrus, there was something nagging me about that picture, but I didn't realize until now what it was. That's a '73; mine's a '72. You can tell because the side markers are 3-section jobbies and mine are single.
