Wheatstone bridge -- Why set all 4 resistances equal?
The Wheatstone bridge achieves maximum sensitivity when all four resistances (A, B, C, and D) are equal due to the balance condition A/B = C/D, which minimizes the current through the galvanometer. This balance leads to a situation where small changes in resistance produce the largest changes in current, enhancing sensitivity. The sensitivity can be mathematically defined as the derivative of current with respect to any resistance, indicating that equal resistances yield optimal sensitivity. By analyzing the system of equations derived from the sensitivity definition, it becomes clear that equal values provide the best performance. Thus, maintaining equal resistances is crucial for achieving high sensitivity in Wheatstone bridge applications.
arvindsharma
Can someone explain me,why Wheatstone bridge is most sensitive when all four resistances say A,B,C and D are equal?as far as i know condition for Wheatstone Bridge is A/B=C/D.
Wheatstone bridges used to employ a galvanometer as a null detector.
Solve the bridge for current through the galvanometer ...
Recipe:
From theoretical considerations of the bridge circuit, current through the ideal galvanometer can be understand as function of 4 variables:
IAC=V⋅f(R1,R2,R3,R4)​
Definition of the sensitivity is:
S=dIAC/dRx
where Rx can stand for any of R1,R2,R3 or R4.
Say Rx=R4 and given the condition of the balance R4=R2⋅R3/R1, one searches for the stationary points of multivariable function S by solving the system:
∂S/∂R1=0
∂S/∂R2=0
∂S/∂R3=0
Likes arvindsharma
You can vary the thing and still get good results. i.e. the right leg has the same ratio as the left leg is good and sufficient.
To see why the system works better with equal values, find di / dRtest (i in galvenometer) as a function of the values with one value, Rtest set. Then set di/dR to zero to find the maximum sensitivity...
Likes arvindsharma
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
