- 1,487
- 4,934
nsaspook said:
I can now see the video and Yes. But 'Volts" and 'Through' rankles a bit. The discharge (=current) goes through. All very well in a fun video but people take that sort of thing into basic electrical problems and it can all go to hell. There are less confusing ways to title a video.Drakkith said:I believe the 'speed' is referring to the FPS of the camera.
sophiecentaur said:But 'Volts" and 'Through' rankles a bit.
Those that will be confused, will be that way with any video title.sophiecentaur said:I can now see the video and Yes. But 'Volts" and 'Through' rankles a bit. The discharge (=current) goes through. All very well in a fun video but people take that sort of thing into basic electrical problems and it can all go to hell. There are less confusing ways to title a video.
If you spill a bunch of batteries into a stream, are the volts flowing now?davenn said:Yeah, volts dont go through anything
Drakkith said:If you spill a bunch of batteries into a stream, are the volts flowing now?
That's a view which can lead to mis-education from the very start. It doesn't excuse the bad title and reflects badly on the presenter.nsaspook said:Those that will be confused, will be that way with any video title.
Lost battle. Those that are curious about why, might get educated, those that are not, won't remember the title, only the sparks.sophiecentaur said:That's a view which can lead to mis-education from the very start. It doesn't excuse the bad title and reflects badly on the presenter.
Where does the initial wavefront come from?Guineafowl said:Could it be said that the connecting wires have some velocity factor, eg 0.7, and the electric (electromagnetic?) wavefront travels at 0.7c around the outside of the wire, which acts as a sort of ‘waveguide’?
Would it also help to think of current not as electrons drifting along like little ball bearings, but as quantum ‘things’, jiggling randomly, which acquire a net direction as the wavefront passes?
The terminals of whatever power supply they have?tech99 said:Where does the initial wavefront come from?
Yes, that works for me. But the charges inside the wire (the waveguide part) are also involved. Ultimately it's a bit too complex to be described by simple phrases.Guineafowl said:Could it be said that the connecting wires have some velocity factor, eg 0.7, and the electric (electromagnetic?) wavefront travels at 0.7c around the outside of the wire, which acts as a sort of ‘waveguide’?
A ‘negative’ wavefront? Does an opposite wavefront travel the other way around the circuit?tech99 said:One of these terminals has an excess of electrons on it, waiting to "go". That is the initiation of the wavefront. We require electrons to initiate the electric field of the wavefront.
I did see those, and the responses from other channels. Interesting, but no substitute for understanding at the deepest levels, of course. More on the level of Feynman’s ‘fun to imagine’ descriptions. A good start for learning transmission line theory.DaveE said:Yes, that works for me. But the charges inside the wire (the waveguide part) are also involved. Ultimately it's a bit too complex to be described by simple phrases.
There are some good Veritasium videos about this.
2. I do not agree with this statement . The wave follows the wire, as a waveguide, so that if the wire is in a tortuous path, say a helix, the wave will tend to follow round the curves at nearly the speed of light.Guineafowl said:A ‘negative’ wavefront? Does an opposite wavefront travel the other way around the circuit?
Two important points I took away from that:
1. When you rig up the circuit (switch open), you leave enough time for the surface charge to arrange itself, such that the charge imbalance is right across the switch terminals. I assume this happens at near c.
2. The timing of the initial current at the fuse wire/load depends on the straight line distance between the switch and load, regardless of the length of wires.
Does this current pulse fade away, to be replaced by the much larger one travelling along the wire ‘waveguides’?
Since the fuse wire and connecting wires might have different characteristic impedances, are there reflections and ringing going on that can explain what’s seen in the slo-mo video?
What I said seemed to be the conclusion of Veritasium’s experiment? Time to first current pulse in the bulb was 1m/c seconds, determined by the 1 m straight-line distance from switch to bulb, rather than the 1 second you’d expect as the wires were 1c metres long, assuming a velocity factor of 1.tech99 said:2. I do not agree with this statement . The wave follows the wire, as a waveguide, so that if the wire is in a tortuous path, say a helix, the wave will tend to follow round the curves at nearly the speed of light.
