When does an atom become a cation and an anion?
  • Thread starter Thread starter gmianosi
    Chemistry
Cations are formed when an atom loses electrons, resulting in a positive charge, while anions are created when an atom gains electrons, leading to a negative charge. Atoms typically aim to minimize energy, so those with fewer than four electrons in their valence shell tend to lose electrons and become cations, whereas those with more than four gain electrons to become anions. The discussion highlights the complexity of ionization for elements like silicon and lead, which both have four valence electrons. Silicon generally forms covalent bonds rather than ionic ones, despite its potential to exhibit a +4 charge in compounds like silicon dioxide. The distinction between losing or gaining electrons versus ions is emphasized as crucial for understanding ion formation.
gmianosi
Cations have a positive charge because they lose electrons, and anions have a negative charge because they gain ions. The atom would always want to do what requires the least energy, like if it has 1 electron in its valence shell, it will give it away, becoming a cation, while if it has 6 electrons in it valence shell, it will gain 2, becoming an anion. So basically, if an atom has over 4 electrons in its outer shell, it will become an anion, and if it has under 4, it will become a cation. Now my confusion is, what if it has 4 electrons in it's valence shell.. Like Silicon, does it lose them or gain 4?
I am only referring to when there are 8 electrons in the valence shell.
Atoms like carbon and silicon are pretty difficult to ionize. Even nitrogen and boron don't ionize very easily.
But still, how does silicon ionize? the question is asking me to ionize silicon and lead.. both have 4 electrons in their valence shell
Well, reality is a little more complicated than your chemistry text. I think lead usually goes +2 or + 4. Silicon, I don't know. I don't know of any ionic silicon materials. The most common form in nature is silicon dioxide, which suggests +4, but I believe it's actually covalent, not ionic.
The chemistry text is probably wanting you to show that they can do both. Carbon can go to positive or negative depending on what it is with. However in reality it does mostly form covalent compounds as opposed to ionic ones. Oh and it is electrons that it gains or looses not ions. It BECOMES and ion when it has a charge by loosing or gaining ELECTRONS important distinction. I wouldn't give you full credit for the explanation you use.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
21K
