I When is Â(r) Ψ(r) = ⟨r | Â | Ψ⟩?
LightPhoton
Wikipedia says that the equation in the title is defined to be true.
But is it true always?
Working with the right-hand side,
$$\langle \mathbf r\vert\hat A\vert\Psi\rangle=\int\langle \mathbf r\vert\hat A\vert\mathbf r'\rangle\langle\mathbf r'\vert\Psi\rangle\ d\mathbf r'$$
If we assume that ##\langle \mathbf r\vert\hat A\vert\mathbf r'\rangle=\hat A(\mathbf r)\delta(\mathbf{r-r'})##, then above expression collapses to ## \hat A(\mathbf r)\Psi(\mathbf r)##. But how to show this in general?
Conventionally
\psi(r)=<r|\psi>
So
\phi(r)=<r|\phi>=<r|\hat{A}|\psi>
where
\hat{A}|\psi>=|\phi>
So I prefer the notation for the definition
[\hat{A}\psi](r)=\hat{A}\psi(r) \equiv <r|\hat{A}|\psi>
with no (r) for A. I have no idea what ##\hat{A}(r)## could mean.
Likes Albertus Magnus, LightPhoton, Demystifier and 1 other person
It's worth noting the formalism here. We start with ##r## as the coordinate(s) of a point in space. I.e. ##r \in \mathbb R^3##. And we have ##|r\rangle## as the position eigenstate (or eigenket) associated with that point. We also have some state ##|\Psi \rangle##.
Now, we can define a complex-valued function (on ##\mathbb R^3##) by:
$$\Psi(r) \equiv \langle r|\Psi \rangle$$Where ##\langle r|## is the bra associated with the eigenket ##|r\rangle##.
Next, we have some operator, ##\hat A##, that acts on the Hilbert space of states/kets. From this we can define an operator, ##\hat A(r)## in this notation, on our function space of complex-valued functions, using:
$$[\hat A(r)\Psi](r) \equiv \langle r|\hat A|\Psi \rangle$$Note that this notation is slightly odd and it would be more usual to write something like ##\hat A'## or ##\hat A_f##, to indicate that this operator is technically not the same as ##\hat A##, but acts on the function space - rather than the space of states/kets. I.e. I would tend to write:
$$\hat A' \Psi(r) \equiv [\hat A'\Psi](r) \equiv \langle r|\hat A|\Psi \rangle$$In any case, note that this defines the action of the operator ##\hat A'## on any function ##\Psi##.
Likes PeterDonis and LightPhoton
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
