When is the work on a spring negative and when is it positive?
The discussion centers on understanding the signs of work related to springs in the context of the work-energy theorem. When a glider attached to a spring moves away from the spring, the work done by the spring on the glider is negative because the force exerted by the spring opposes the glider's displacement. Conversely, if the glider moves towards the spring, the work done is positive, as both the spring force and the glider's displacement are in the same direction. The confusion often arises from the application of Newton's third law, which indicates that both work done by the spring and work done on the spring must be considered. Overall, using conservation of energy can simplify the analysis of these situations.
PhyIsOhSoHard
I have a problem understanding whether a sign should be positive or negative when it comes to a spring.
In my book, there is an example with a glider attached to a spring, and the glider is moving away from the spring so it expands.
It says that in order to use the work-energy theorem, it has to be the work done by the spring on the glider, which is the negative of the following equation:
W=\frac{1}{2}mv_2^2-\frac{1}{2}mv_1^2
Can somebody explain the "work done by the spring" and "work done on the spring"? How do I know which situation I have?
Why is the work negative in this situation?
And if the glider went the opposite direction, towards the spring, would that mean the work-energy theorem is positive?
Direction of spring force is always against its extension . Since F = - kx if the this is opposite to instantaneous displacement of body then negative work is done or if it is along the displacement positive work is done
you are not alone.
Yes, but that is confusing, isn't it?
By Newton's 3rd law, you always have both situations, but usually you are looking at work done on the object by the spring.
Work done on an object by a spring is negative when the displacement and force on the object are in opposite directions. When the glider is moving away from the spring, it is pulling on the spring, so by Newton 3, the the spring is pulling back on the glider. Since the force on the glider is back, but the displacement of the glider is forward, work done by the spring on the glider is negative.
Yes, the direction of the spring force on the object is back (it is pulling it back), and the glider is moving back, same direction, work is plus. It is often better to use conservation of energy equation rather than work-energy, since the plus/minus signs can be handled easier. But nonetheless, it is a good exercise using work-energy.
Likes 1 person
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
