When you drive a .36 kg apple, Earth exerts a force on It that
When a .36 kg apple is driven downward, Earth exerts a force that accelerates it at 9.8 m/s². According to Newton's third law, the apple exerts an equal and opposite force on Earth. To find Earth's acceleration towards the apple, one must apply the formula F=ma, using the apple's mass and the gravitational force it experiences. The discussion emphasizes the importance of correctly identifying forces and masses in calculations. Ultimately, the numerical solution for Earth's acceleration is derived from the relationship established by these forces.
KellySierra22
When you drive a .36 kg apple, Earth exerts a force on It that accelerates it at 9.8 m/s squared toward the Earth's surface. According to Newtons third law the Apple must exert an equal but opposite force on earth. If the mass of the Earth is 5.89x10^24 kg,what is the magnitude of the Earth's acceleration toward the apple?
I have tried this problem a couple of times and get it wrong. My math is: .36*9.8/5.98x10^24.
Hello KellySierra22,
Instead of giving your workings with numbers, it is easier to understand the problem in algebra.
We start with the well known F=ma, however we must be careful about which force and which mass (although the acceleration is constant). So I label them
F_{apple \rightarrow earth}= m_{apple} \times g_{apple \rightarrow earth}
That is the force the Earth exerts on the apple is the mass of the apple times acceleration, you must calculate this force first. Now that you have done so we can use Newtons third law
F_{apple \rightarrow earth}=F_{earth \rightarrow apple}
It may help to draw this pictorially. So you now have an equation relating the force you already have to the force the apple exerts on the earth. You can now calculate the acceleration on the Earth from the apple using
F_{earth \rightarrow apple}= m_{earth} \times g_{earth \rightarrow apple}
You must solve for the acceleration of the Earth towards the apple.
Hello KellySierra22, Welcome to Physics Forums.
The expression that you have shown should give you the numerical value for the acceleration of the Earth towards the apple. What value did you obtain when you completed the math?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
