Where Can I Find Engineering Exam Questions Online?
Engineering exam questions can be found online through resources like MIT's OpenCourseWare, which offers a variety of tests across different subjects. A general search on Google also yields numerous sample questions, both solved and unsolved. The discussion includes a query about solving a specific equation involving a sum series, particularly when the number of additions becomes large. A suggestion is made to find a closed expression for the sum of e^k from 0 or 1 to n and then equate it to the known sum to solve for n. Overall, the conversation emphasizes the availability of resources for engineering exam questions and methods for tackling complex equations.
matqkks
Does anyone know where I can find engineering exam questions on the web. I am trying to do a survey of various questions from different universities.
Mathematics news on Phys.org
Just on Googling you can find a lots of sample questions solved and unsolved.
I am trying to solve an equation that involves sum series and the unknown is the number of times i have to add, this is easy to solve just by guessing when the number of additions is small, but if it gets large... is there any analytic way to solve this kind of equations?
form:
sum (e^n) from n b to x = a;
@diegojolin: find a closed expression for the sum(e^k), from 0 (or 1) to n.
then equate it to the known sum then solve for n.
Oks, thanks, I've tried and at least the computer seems to work faster this way
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
