Where can I find low-profile multi-axis rocker switches or joysticks?
  • Thread starter Thread starter Averagesupernova
    Switch
The discussion focuses on finding low-profile multi-axis rocker switches or joysticks, ideally with a handle height of no more than 3/4 inch. Users suggest various sources, including 3Dconnexion and Happ Controls, while also mentioning Allied Electronics as a potential supplier. One participant notes the need for an outdoor-rated joystick, expressing concerns about the durability of certain models. There is also a mention of membrane keypads as an alternative to joysticks, though concerns about availability and production costs are raised. The conversation highlights the challenge of sourcing suitable components for specific applications.
Averagesupernova
Can anyone point me to a source of multi-axis rocker switches? Similar to a joystick, but a lower profile. A joystick is acceptable too, but most have too high of a profile. The handle should ideally be no higher than about 3/4 inch. I've tried the obvious sources through www.globalspec.com and have done some googling but come up with only one 2 axis rocker from Penny Giles. Thanks in advance.
Allied Electronics has just about everything.
How about this?
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=948-0343&SEARCH=&ID=&DESC=04A%2DB01&R=948%2D0343&sid=47476980905E17F&tab=overview#tab
Data sheets:
http://www.alliedelec.com/Images/Products/Datasheets/948-0343.pdf
You could also just obtain a cheap joystick and cut the handle off...
That one from Grayhill looks pretty promising. I do recall seeing it while looking for another product and couldn't remember where I had seen it. I don't see an IP rating on it though and it needs to live outdoors. There are joysticks out there that have IP ratings suitable for being exposed to a high pressure water jet. I would prefer one like that. I don't think the Grayhill joystick looks good enough to survive outdoors. I could be wrong, I'll look into it.
Danger, this switch is to be used in production. I'm not ready to cut the handle off of anything just yet.
Membrane keypads generally aren't available off-the-shelf, but if anyone knows of anything I'd appreciate it. I'm not sure what tool-up costs are and if it would be worth it for smaller quantities. A membrane keypad with 4 keys could certainly replace a joystick.
Ah, I thought that this was just a personal project. How about trying to find a source for those obsolete Mattel Intellivision consols? The controllers were just basic joystick internals, but with a disk on top rather than a stick. How many do you need?
