Where Can the Electric Field Be Zero Between Point Charges?
  • Thread starter Thread starter dswatson
    Field Physics
The discussion centers on identifying regions where the electric field is zero between a positive charge (2q) and a negative charge (-q) separated by a distance d. Conceptually, the electric field will be zero at a point between the two charges where their opposing fields cancel each other out. Participants emphasize the importance of visual aids, such as diagrams with arrowed lines indicating field strength and direction, to clarify the concept. The initial request for a conceptual explanation highlights the need for a deeper understanding beyond mathematical calculations. Visual representations proved to be beneficial in grasping the concept effectively.
dswatson
A charge 2q and a charge -q sit a distance of d away from one another. In what region of space can the electric be zero? The answer has to be answered conceptually and not mathematically. Pictures would be helpful. I understand how to do the problem mathematically and that at some point between the two charges would be a spot where the E-field is zero. Can someone help me explain this? Thank you in advance.
Draw a picture. In each region of the line passing through the charge centers and defined by the charge placements, indicate the field strength and direction for each charge with arrowed lines. Discuss.
ok just drawing a picture with the arrowed lines was a huge help thank you
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
