I Where do discontinuities in the electromagnetic field occur?
Discontinuities in the electromagnetic field occur at point charges and along boundaries, particularly where surface charge densities exist, leading to jumps in the normal component of the electric field. In superconductors, the treatment differs from conventional conductors, as they cannot simply be modeled with zero resistance or infinite conductivity; the London theory provides a more accurate framework. The finite resistance in conductors allows electromagnetic waves to penetrate slightly, preventing discontinuities at the microscopic level. Additionally, phenomena like total internal reflection demonstrate that reactive fields can exist even behind reflecting surfaces. Understanding these concepts is crucial for analyzing electromagnetic behavior in various materials.
cuallito
Obviously at point charges, but where along boundaries? Would they theoretically occur in superconductors since they can carry infinite current (J -> infinity)?
One example are jumps of the normal component of the electric field along conducting surfaces, carrying a surface charge density. The jump is ##E_{n1}-E_{n2}=\sigma/\epsilon_0##.
Superconductors must be treated differently. They cannot be described by simply making the resistance 0 (or the electric conductivity to ##\infty##). A nice effective theory is the London theory:
https://en.wikipedia.org/wiki/London_equations
In practice the resistance of the conductor allows the wave to slightly penetrate. I think the problem in general is that the wavelength is finite and so there is no discontinuity at the microscopic level. For instance, total internal reflection in a prism is accompanied by reactive fields in the air behind the reflecting surface.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
