Where Does Earth's Counter Gravity Go in an Expanding Universe?
In summary: Hubble first observed that the universe is expanding with a non-constant, accelerating velocity, and that this is caused by the mass of Earth. Additionally, GR states that gravity is caused by curvature of space-time, and that this curvature is created by all the energy and momentum content in the universe. If Earth is part of the expanding universe, then it is expanding with a certain direction (into the future), however, there is no 'extra push' created by Earth.
  • #36
Somewhat related to this topic, here's a really cool simulation of the merger of two black holes:
What you're seeing here is a visualization of the event horizon, with the colors indicating the curvature scalar at the various points (it's different around the equator of the black hole because it's spinning).
What's really interesting here is that the event horizon distorts when the merger takes place. Throughout this process, the pair emits gravity waves, and this continues until the final black hole relaxes into its final shape (which takes very, very little time after the two black holes touch).
Space news on Phys.org
  • #37
PeterDonis said:
Sure, because any change in the motion of the hole will be driven by the behavior of mass somewhere outside its horizon.
Peter, Going to have to think some more on this one but I really appreciate your input. James
  • #38
Chalnoth said:
Yes. But that pressure has no direct impact on expansion. However, pressure also acts as a source of the gravitational field, so that it impacts how gravity behaves.
This is probably made clearest by considering a box containing a negative-pressure substance, with zero pressure outside the box. The pressure would be pulling the sides of the box inward.
I think talking about the cosmological constant in terms of the pressure can be confusing. The simplest way to think of it is this: the curvature of the universe is a function of how much stuff there is in the universe. It manifests itself as the rate of expansion. Because the cosmological constant is constant, you get the same amount of stuff at all times, which means the curvature is constant, which means the rate of expansion is constant. A constant rate of expansion leads to exponential growth of the distances between objects.
But the rate of expansion is not constant, it is accelerating.
  • #39
Chalnoth said:
It's still described as a force. General relativity doesn't change the usage of this term.
True, but the usage is habit, just as we talk about centrifugal force in basic physics, but in more advanced mechanics courses is referred to as a pseudo- force, with explanation of course. Then we all go right on talking about centrifugal force. o_O
  • #40
The rate of expansion is usually defined as ##\dot{a}/a##. This rate is currently decreasing and seems to be approaching a constant value (proportional to the square root of the cosmological constant). When you have a differential equation given by:
[tex]{\dot{a} \over a} = H_0[/tex]
where ##H_0## is a constant, then ##a(t)## has exponential growth. The solution is:
[tex]a(t) = a(0) e^{H_0 t}[/tex]
So it's not the rate of expansion that is accelerating, but the distances between objects.
  • #41
It's usually the other way around. In basic classes, people usually talk about centripetal forces, which are so-called "real" forces. The centrifugal force is usually not dealt with until you get to pretty advanced mechanics courses (as doing physics in rotating coordinate systems is a beast).
Regardless, there's no reason to say that the spin-1 mediated interactions are forces, while the spin-2 mediated interactions (gravity) are not.
  • #42
Chalnoth said:
An overly-simplified way of stating it is that the field updates at speed c, as gravity waves propagate the changes through the field.
The more complicated way of saying this is that some apparent changes to the field don't need any updates, and so appear to propagate instantaneously. To see how this might work, consider linear motion. With regard to linear motion, simple consistency requires that if we want the gravitational field of a black hole moving linearly, that field must be identical to the field we get from simply taking the black hole's space-time, and transforming to coordinates that are moving with respect to the black hole. This requirement ensures that an object near a moving black hole will be pulled towards the center of the black hole, not towards the position it was 7 minutes ago if the black hole is 7 light minutes away.
It turns out that when you work through the math, gravity not only doesn't need to update for linear motion, but it also doesn't need to update the field for acceleration.
Changes in acceleration, however, need to update, and an object which is changing its acceleration will radiate gravity waves (though typically very, very little unless the change in acceleration is massive, such as for an object very close to a neutron star or black hole).
Thanks for the detailed explanation, that does help a lot!
The discussion of black holes has however generated a new question that I am hoping that someone can help me with. As I understand things, matter being drawn into a black hole from our perspective slows as it approaches the event horizon and if we could see the matter once it reached the EH it would appear frozen ( motion would appear to cease) due to the extreme time dilation. I envision that if we could cut a slice through a black hole and examine it, that we should not see any obvious motion below the EH for the same reason though I understand that we may never know for sure. I don't have a problem with this part but what I don't understand is how the mass located behind an EH can effectively be frozen in it's collapse and yet be free to move through the Universe in every other sense? How is movement of matter towards the center of a black hole any different than this same matter moving through space? James
  • #43
Your understanding is not correct. You are confusing an effect of the spacetime curvature of a black hole on light rays emitted outward by infalling objects, with an effect on those objects themselves. Infalling objects appear to slow down because of the way the spacetime curvature of the hole affects the light rays those objects emit. But someone falling along with the objects would not see them slow down; everything would look perfectly normal.
We can't. A black hole is not an ordinary object, and it is not correct to think of the region inside the horizon as similar to the region inside the surface of a planet or star. The interior of a black hole is very different.
  • #44
I have imagined along similar lines. It's certainly the case that this doesn't happen with straight general relativity, or even with general relativity with hawking radiation added. In both cases the matter entering the event horizon reaches the singularity in finite time.
But if the horizon is only an apparent horizon, then it is conceivable. In this case, the black hole might be thought of as a sort of massively time-dilated collision, with matter going in and hawking radiation coming out. The ingoing matter gets highly randomized in this situation due to the extreme nature of the spacetime in the black hole.
Likes James Alton and julcab12
  • #45
I assume you are referring here to various speculative quantum models, where quantum effects prevent an actual event horizon or singularity from forming, and instead the collapsing matter gets converted to outgoing radiation. In these models, there is indeed only an apparent horizon--that is, a surface at which, locally, outgoing light does not move outward, but stays at the same radius. From the viewpoint of a distant observer, objects falling through this apparent horizon will indeed look similar to objects falling through the event horizon of a Schwarzschild black hole; their light will be redshifted and they will appear to slow down. However, again similarly to the case of the Schwarzschild black hole, an observer falling inward with the object will not see any slowdown; his clock will tick perfectly normally, and he will see objects around him behaving normally. Only when the infalling observer reaches the region inside the apparent horizon where quantum effects become strong will anything different happen to him--and at that point, what happens is not that he sees time slowing down, but that he gets destroyed and converted into Hawking radiation.
  • #46
"In both cases the matter entering the event horizon reaches the singularity in finite time" Thanks so much for this insight! I have read in a number of places that time inside of a black hole actually stops and it never made sense to me…this really helps me a LOT. Does time dilation ever reach a maximum value with increasing gravity or does the curve just keep flattening? I have this weird feeling that the shape of the curve is going to resemble the increasing energy required to accelerate mass to velocities approaching c but I am just guessing... It would be wonderful to see a graph or some data that was easy to understand to help me get a better grasp of how to compare different time frames. (hopefully I said that correctly, if not please let me know)
Would it be correct to say that the matter falling into a black hole approaches c within it's time frame reference? If so then can we say that it is the speed limit of c combined with the extreme time dilation that is responsible for the apparent freezing of matter at the event horizon? Absolutely fascinating discussion, thanks again! James
  • #47
"Gravitational time dilation" is only a meaningful concept outside the horizon. At or inside the horizon, there are no static observers--i.e., no observers who stay at the same point in space for all time--and gravitational time dilation is defined relative to those observers; it's the difference between the clock rate of a static observer at some finite altitude and the clock rate of a static observer at infinity.
No. Any object (more precisely, any object with nonzero rest mass) is always at rest in its own frame of reference. What happens as an observer falls into a black hole is that, as he passes static observers closer and closer to the horizon, they are moving closer and closer to ##c## relative to him. And when he actually passes the horizon, it is moving at ##c## relative to him.
  • #48
"Your understanding is not correct" That is certainly possible! I do accept the fact that from the reference of frame of someone falling into a black hole that the passage of time should look perfectly normal. I am still confused about why matter falling into a black hole is slowed from our distant perspective while that same matter can move through space in a way that looks normal to us.We can't. A black hole is not an ordinary object, and it is not correct to think of the region inside the horizon as similar to the region inside the surface of a planet or star. The interior of a black hole is very different.
I did not realize that I implied any similarities between a black hole and the inside of a planet or star, sorry for any confusion as that was not my intent. I have been told by a number of different sources that time inside of a black hole stops and as such the analogy of taking a (frozen) slice and examining the apparent lack of movement seemed helpful at the time. Thanks for your input. James
  • #49
As you should realize by now, those sources are wrong.
  • #50
No. The apparent "freezing" of matter as it approaches the horizon is because of the effect on outgoing light rays of the gravity of the black hole; those light rays are extremely redshifted and slowed down as they climb out to the observer very far away.
  • #51
I meant this in the literal sense rather than as would be seen from an observer but I should have been more clear. James
  • #52
Well, I think that what I am learning the most about is to not take to many definite personal positions and to keep asking questions! (grin) But yes, the idea of time actually stopping at the EH or inside of a black hole never made sense to me and I certainly appreciate the information I am getting here. James
  • #53
And just to be clear, in the "literal sense", meaning, I assume, what the infalling observer actually experiences, there is no slowing down of time.
  • #54
No, for the purpose of my question I was hoping to eliminate the observational complications to the problem and just discuss what would be actually physically happening and tie it to our distant perspective. Yes, I do realize that this would probably be impossible to do. Assuming that time continues to progress rather than stopping at the EH as some sources indicate to be the case, your explanation of the passage of time for an observer falling into a black hole makes sense to me. Thanks for all of your helpful input. James
  • #55
Yes, from an observational perspective this does sound correct to me. What interests me more however is what is actually physically happening rather than just what could be observed. Thanks, James
  • #56
What is actually physically happening is easy: as I said, the infalling observer sees no slowdown of time; everything around him happens normally. But there is no way to "tie it to our distant perspective" that does not involve a choice of convention. There simply is no invariant fact of the matter about how the "distant perspective" is related to what is happening locally to the infalling observer.
  • #57
No. No matter is ever moving at all in its own reference frame. And no matter will ever outrun a light ray.
  • #58
That's what I said. In intro courses centrifugal forces are talked about like real forces, and in more advanced course they are called pseudo- or fictitious courses, then we all revert to using centrifugal force, or coriolis force or whatever. We tend to use abbreviated language for convenience. I would hate to see meteorologists using non-inertial reference frames in calculating coriolis forces at different latitudes. As you say, it would be a beast.
Regarding gravity, all that can be said is that Einstein showed gravity not be a Newtonian central force but a property of spacetime when mass is present. The spin-2 mediator for gravity, the graviton, is still hypothetical. If it is ever discovered, then I'll come back and retract everything. :sorry:
  • #59
I said centripetal. A centripetal force is a force that keeps an object moving in a circular path, and is opposite and equal to the centrifugal force that is seen in the rotated reference frame. The centripetal force is considered a real force, while the centrifugal force is considered fictitious.
Most introductory physics classes take great care to talk only about the centripetal force.
  • #60
Sorry. Mea culpa et cetera.
  • #61
I understand the simple ODE. But the scale factor of the universe, a(t), is not constant, and neither is the Hubble parameter. I don't understand your last sentence.
  • #62
There are two different things here.
1. The rate of expansion is the Hubble parameter. This is decreasing and approaching a constant value.
2. The distances between objects are increasing in an accelerating manner.
  • #63
Is there any effect on for example the Earth, due to its deceleration in all directions simultaneously compared to the 'fixed stars'?
  • #64
The stars aren't fixed. They're orbiting the milky way. Within the milky way, the expansion has no impact at all.
  • #65
Hence, 'Fixed Stars' being in quotes.
I suppose it's much the same as calling gravity a force. I have to confess I haven't heard the term for a very long time, but it was often used, even in the heavier end of science books for the layman a couple of decades ago. I had a feeling back then that they didn't emphasize the almost 'mechanical isolation' of a galaxy clearly enough.
Anyway, to the point. Surely Earth for example, must be decelerating in all directions simultaneously compared to the bulk of the observable universe, and specifically, not our galaxy. What could be the effects of such relative motion?
  • #66
You are confusing recession with proper motion. They have nothing to do with each other. The proper motion of the receding galaxies relative to Earth is trivial compared to the recession speed, which by the way is about 3c for objects at the edge of the Observable Universe. There is no effect due to recession speed (other than that we see them red shifted)
  • #67
Talking about this effect in this way doesn't make any sense.
There is a real effect where the expansion of the universe acts as a sort of friction, in that if you have one object which is moving at a high velocity in some direction compared to the background, then it will "catch up" to parts of the universe that are in that direction, becoming slower relative to its nearby surroundings. This has the effect of making the expansion more uniform over time (on very large scales).
But this effect only appears if you are looking at the whole. If you just look at the Earth, or just look at the Milky Way, there is literally no way to know that this is happening at all. There is zero impact.
It gets even worse when you realize that local gravitational attraction dominates over this effect at scales smaller than a few million light years.
  • #68
Not so much confusing, as failing to make clear the question details. It's just that an accelerated object, in my limited understanding, undergoes a change in the direction of motion. I wondered what the effects might be on something that was decelerating in all directions simultaneously relative to the total mass of all matter in the Universe.
I find it fascinating that such a phenomenon, in any event, would not be detectable.
The difference in types of motion: Do you used the terms 'Co-moving velocity' and 'actual motion'? Also that the movement of the galaxy through the expanding Universe is often called the 'Peculiar velocity'?
At this point, I'm not addressing the problem of the latter being too small to have any significant effect.
  • #69
Hm ... didn't seem that way to me, but OK.
then your understanding is incorrect. Acceleration does not require a change in direction, just speed. A change in direction does imply acceleration but acceleration does not imply a change in direction.
I have no idea what you could possibly mean by that concept.
  • #70
[QUOTE="phinds, post: 5225841, member: 310841
then your understanding is incorrect. Acceleration does not require a change in direction, just speed. A change in direction does imply acceleration but acceleration does not imply a change in direction.[/QUOTE]
Oh dear. Goes to show how careful one has to be.
What I failed to say was 'undergoes a change when accelerated along the line that it is traveling'. I was intentionally not using terms like 'Length contraction', but I did mean shortened in the direction of motion, or contracted. I also avoided using the term 'Lorentz contraction' as it would be pretentious to do so. But, what I am questioning is the possibility of any physical body in the Universe undergoing what is in effect, the reverse of such a change in all directions simultaneously.
I can well understand your reaction to such a concept.
