Where does heat energy go when dissipated in metal?
When heat is dissipated in metals like aluminum, the potential energy stored in heat transforms into kinetic energy, causing atomic vibrations. This process spreads the heat over a larger volume, leading to a temperature decrease at the original point and an increase in the metal. Heat sinks are crucial in electronics, preventing overheating of components like power transistors by effectively managing heat dissipation. While there isn't a super efficient method to capture the kinetic energy from heated atoms, various heat engines, such as steam engines and jet engines, convert heat energy into mechanical or electrical energy. Overall, the dissipation of heat in metals plays a vital role in thermal management and energy conversion.
Kyle Gray
When heat is dissipated into a piece of metal(aluminum for example), what happens to the potential energy that was stored in the heat? Does it transform into another form of energy or is it absorbed by the atoms of the metal element?
Science news on Phys.org
Dissipation means that heat concentrated in a small area gets spread out into a larger area.
The energy hasn't gone away it is just contained in a larger volume
Hence the temperature at the original point falls, while it rises in the material the heat was dissipated into.
This how heat sinks work in electronic equipment.
Power transistors generate a lot of heat and would quickly burn up without a heat sink.
It turns to kinetic energy, which makes the atoms it's made of vibrate faster.
I would like to know if there is a super efficient way to capture the kinetic energy from the atoms as they heat up?
I don't know of a super efficient way, but there are many examples of heat engines which do useful work by converting heat energy to another form.
A steam engine is the most basic, converting (some of) the heat to mechanical energy.
Then there are jet engines which convert heat energy to a linear thrust force.
Power stations use heat to spin turbines resulting in production of electrical energy.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
