PeterDonis
Mentor
- 49,123
- 25,184
Only if the proposition itself is well defined in the domain of discussion. In QM, many of the propositions you are making claims about simply are not well defined in the domain of discussion.Lynch101 said:A conclusion is either valid or it is invalid
No, I am pointing out to you that interpretations of QM exist in which the wave function is a direct description of the physical reality, the same way the position of a point particle is in classical Newtonian mechanics. You are simply ignoring such interpretations and assuming that the wave function is not a direct description of physical reality.Lynch101 said:It sounds to me like you are confusing the 'map' with the 'territory' here.
No, I don't mean that. Nor do I mean that the wave function is just a mathematical artifact. I mean that the implicit assumptions you are making about "localization" do not apply to wave functions; wave functions are not like classical point particles or finitely extended objects, and the concept of "localization" that works for classical point particles or finitely extended objects does not work for wave functions. So in QM interpretations in which the wave function is a direct representation of the physical reality, your concept of "localization" is simply not well-defined, and the questions you are trying to ask can't even be asked.Lynch101 said:If you mean the physical system to which the wave function corresponds is localized in the finite region of space
This is true, but it also means we have to accept the limitations of deduction and inference, and we have to carefully check our premises and whether they even make sense in the domain of discussion before we try to make any deductions or inferences.Lynch101 said:It might very well be the case that these matters cannot be resolved by appeal to experiment and must remain in the domain of interpretation. That doesn't mean, however, that we cannot deduce or infer the necessary consequences of a given position or determine what implications they imply.
