I Where is this term coming from?
  • I
  • Thread starter Thread starter bigmike94
    Term
The discussion revolves around the origin of an extra term in a mathematical expression, specifically related to the product rule in vector calculus. Participants clarify that the term likely arises from the x-direction component, denoted as x i-hat, while y and z components are ignored. One user expresses gratitude for the insight that helped them understand the reasoning behind the inclusion of the extra x. The conversation also touches on the need for proper mathematical notation, suggesting the use of LaTeX for clarity. Overall, the participants collaboratively work through the confusion surrounding the formula's components.
bigmike94
TL;DR Summary
I am back again to ask for your mathematical help.
I got the same result apart from that extra x in the second term? I have boiled it down to that it must have come from maybe the x hat j hat and z hat part of the product rule? Any help would be grateful thank you!
It comes from numerator of the formula above, x i-hat.
@bigmike94 can you write down what ##A_x## is?
Yeah I had a guess what assumed that was it but why is it included and not y or z aswell? Maybe I am missing an i hat which will get rid of the j and z hat cos of the dot product?
I’m not sure how to type maths in here but I think you have just helped me crack it, because it’s in the x direction only we ignore y hat and z hat, then In the product rule you’re left with the extra x.
I’m not sure if that makes sense to you? But yeah I think I get it now thank you
By definition $$\vec A = A_x \hat i + A_y \hat j + A_z \hat k$$This can also be expressed as:$$A_x = \vec A \cdot \hat i$$
You need to learn some LaTex:
https://www.physicsforums.com/help/latexhelp/
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
