Which disks are in equilibrium?
  • Thread starter Thread starter taliaroma
    Equilibrium
The discussion focuses on determining which of the four rotating disks shown in Figure 12-16 are in equilibrium under the influence of various forces. Disks a and c are identified as being in equilibrium, while disks b and d are not. The net torque for disk c is questioned, with the user unsure how to demonstrate that it equals zero despite the net force being zero. A response clarifies that taking moments about the center of the disk reveals that the forces create equal and opposite torques, resulting in equilibrium. The conversation emphasizes the importance of analyzing both net force and net torque to establish equilibrium conditions.
taliaroma
Figure 12-16 shows four overhead views of rotating uniform disks that are sliding across a frictionless floor. Three forces, of magnitude F, 2F, or 3F, act on each disk, either at the rim, at the center, or halfway between rim and center. The force vectors rotate along with the disks, and, in the “snapshots” of Fig. 12-16, point left or right. Which disks are in equilibrium?
2. \tau_{}net = 0
\tau = r(perpendicular)F
3. So I'm pretty sure that I understand why b and d are not in equilibrium, and I'm pretty sure that I understand why a is in equilibrium. I don't know how to figure out why c is in equilibrium, though. I can figure out that net force is 0, but I don't know why net torque is 0. Using the 1st and 2nd equations listed, I got -
\tau_{}net = 0(2F) + R(F) + R(F) = 2RF
where R is the radius. For c to be in equilibrium, the result of this equation has to be 0. How should I do this?
welcome to pf!
hi taliaroma! welcome to pf! :smile:
(have a tau: τ :wink:)
taliaroma said:
… So I'm pretty sure that I understand why b and d are not in equilibrium, and I'm pretty sure that I understand why a is in equilibrium. I don't know how to figure out why c is in equilibrium, though. I can figure out that net force is 0, but I don't know why net torque is 0. Using the 1st and 2nd equations listed, I got -
where R is the radius. For c to be in equilibrium, the result of this equation has to be 0. How should I do this?[/b]
Your second equation should be τ = r x F
if you take moments about the centre of the disc, then r is in opposite directions for the two forces, so the two r x Fs have opposite signs :wink:
however, I do it by just looking at it and saying oh that's clockwise, that's anti-clockwise! :biggrin:
(btw, note that you can take moments about any point, and it still comes out zero … so you can take a point which has all the forces on the same side!)
(and of course you're right about a b and d :smile:)
Thank you!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
