MHB Which Equation Represents a Line Parallel to 3y-1=2x?
The discussion centers on identifying an equation that represents a line parallel to the line given by 3y-1=2x. The slope of the original line is calculated to be 2/3. Participants analyze the slopes of the provided options, concluding that none of them match the required slope for parallelism. There is a suggestion that a typo may exist in the original problem. Ultimately, the consensus is that none of the answer choices are correct.
flnursegirl
The graph of which of the following equations is a straight line parallel to the graph of 3y-1=2x?
A: -3x + 2y = -2
B: -2x + y = 6
C: -2x + 2y = 3
D: -x + 3y = -2
Can you show the work when you answer please? Thanks
Mathematics news on Phys.org
A: -3x + 2y = -2
B: -2x + y = 6
C: -2x + 2y = 3
D: -x + 3y = -2
Usually we ask you to show your work, so we can see where you got stuck.
There are a number of ways to find the slope of a line in the plane-which ones do you know?
Using y=mx+b I got y=2/3x+1 for the first line.
For choice A I got y=3/2x-2
For choice B I got y=2x+6 (the key says this is the answer)
For choice C I got y=1x=3
For choice D I got y=1/3x-2
None of these look correct to me using this method.
For choice C I got y=1x+3
That's a good method, and none of the answers give the same "$m$" value, so it appears your text has a typo. You should use parentheses when you use the "/" symbol, so no one confuses
y = 3/2x - 2, whereby you mean: y = (3/2)x - 2 with:
y = 3/(2x - 2).
Hey flnursegirl! ;)
I agree with your method and with Deveno - none of the given answers is correct.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
