Which Equations constant I use here ?
  • Thread starter Thread starter r-soy
    Constant
To find the original speed of a truck that covers 50 meters in 8 seconds while slowing down to a final speed of 2.5 m/s, the correct equation to use is Dx = (v + v0)t/2. Substituting the known values, the equation simplifies to 50 = (2.5 + v0) * 8 / 2. The calculations reveal that v0 equals 10 m/s, aligning with the answer provided in the book. The confusion arises from incorrect manipulation of the equation, emphasizing the importance of careful algebraic steps. Understanding the correct application of the equation leads to the accurate determination of the original speed.
r-soy
Hi ALL
which Equations constant I use here ?
a truck covers a distance of 50 m in 8 s while smoothly sowing down to a final speed of 2.5 m/s . find its original speed
Dx = 50 m
t = 8 s
v = 2.5 m/s
Now I take this equation bit I don't now why I didn't get the correct answer
Dx = (v + v0 ) t/2
=50 = 2.5 + v0 ) 8 /2
=2 X 50 + 92.5 + v0 ) 8 /2
=100 = 20 + 8v0/2
=128v
v = -128
I think you've just added it up wrongly.
50m = (2.5m s^-1 + v0 ) 8s /2
is right.
Solve for v0.
but here in my book the answe is 10 m/s
they do v0 = 2DX/2-v = 2 X 50 /8 -2.5 = 10
??please I want the help beacuse I fell confused
I wait
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
