Which Functions Are Integrable?
  • Thread starter mechanical eng
  • Tags
    Functions
In summary, a function is integrable if it is bounded and discontinuous on at most a set of measure zero. This means that the anti-derivative of the function can be expressed in terms of sums, products, powers, exponentials, trig functions, and their inverses. However, this condition is not very interesting. Additionally, a function can still be integrable even if it is not continuous, as long as the points of discontinuity are countable and do not contribute to the overall area under the graph.
mechanical eng
what functions are integrable?
if f(x) is continuous on [a,b], then f(x) is integrable of [a,b]
please explain completely and other situations
What exactly do you mean? What kind of answer are you looking for?
Essentially a function is integrable if it is bounded, and discontinuous on at most a set of measure zero.
I suspect you are really asking: when can the anti-derivative of a function be expressed in terms of sums, products, powers, exponentials, trig functions, and the inverses of such. The conditions are not hard to state, but they are not interesting either.
I think a function is integrable if it be dic-continus on countable point
integral
when a function is not continuos how can it be integrable?
Not really treating this rigorously, but the idea is simple. Say f(x) = x at all x except when x=1. Say f(1) = 5.
Then f is discontinuous at the point x=1. But if you interpret the integral as area under the graph, then it is intuitively clear that the integral of f from say, x=0 to x=2, is the same as that of the integral of the identity function from x=0 to x=2. The point at x=1 does not contribute to the area.
So as Crosson said, essentially, a function is integrable if it is bounded, and discontinuous on at most a set of measure zero.
FAQ: Which Functions Are Integrable?
What is integration?
Integration is a mathematical process that involves finding the area under a curve on a graph. It is the inverse operation of differentiation and is often used to solve problems in physics, engineering, and other scientific fields.
What is an integrable function?
An integrable function is a mathematical function that can be integrated using a definite integral. This means that the function has a well-defined area under its curve and can be evaluated using mathematical methods.
What are the properties of an integrable function?
An integrable function must be continuous and bounded on a given interval. It must also not have any infinite or discontinuous points within that interval. The function must also have a finite limit at each point in the interval.
How do you determine if a function is integrable?
To determine if a function is integrable, one can use various mathematical techniques such as the Riemann sum, the Trapezoidal rule, or the Simpson's rule. These methods involve dividing the function into smaller parts and calculating the area under each part to approximate the total area under the curve.
What are some examples of integrable functions?
Some examples of integrable functions include polynomials, trigonometric functions, exponential functions, and logarithmic functions. These functions have well-defined areas under their curves and can be evaluated using definite integrals.
