Which Ions Interfere with CrO4 2- Quantitation?
  • Thread starter Thread starter SebPT
    Cell Ions
The discussion centers on the interference of various ions with the quantitation of CrO4 2- using an electrochemical cell. It is established that the standard reduction potential for the reaction involving Ag2CrO4 is +0.446 V vs. NHE. The participants analyze how ions like NO3-, Br-, S2-, K+, and Pb2+ may affect the measurement, with a focus on their solubility and Ksp values. It is concluded that S2-, Br-, and Pb2+ are likely to interfere due to their tendency to precipitate with Ag+ and affect the half-cell reaction. The role of the reference electrode is deemed irrelevant in this context since the interfering ions are present in the other half-cell.
SebPT
The electrochemical cell:
SCE // CrO4 2- (x M) / Ag2CrO4 (s) / Ag (s)
is used for the determination of CrO4 2- . The standard reduction potential for the reaction:
Ag2CrO4 (s) + e = 2 Ag + CrO42-
(b) Which of the following ions would be expected to interfere with CrO4 2- quantitation if added to the analyte solution:
NO3 - , Br - , S 2- , K + , Pb 2+
3. To solve this I guess I need to understand how the half cell is working. So I think the electrons coming from the salt bridge react with Ag2CrO4 (s) at the surface of the Ag electrode to produce a deposit of Ag on the metal and CrO42- which stays in solution. However I am not sure where the interference will take place. I am not sure if adding K and Pb cations will just take in electrons and reduce current or if some of the anions interfere at the electrode surface. Any help would be greatly appreciated!
Can you write Nernst equation for the measuring electrode?
S.C.E: 1/2Hg2Cl2 (s) + e-⇌Hg(l)+Cl-
Emeas=0.242V-0.05916*log[Cl-]
Note: the half cell rxn in the original post should be
Ag2CrO4 (s) + 2e- = 2 Ag(s) + CrO4 2- (aq)
I don't see how the reference electrode matters in this case, since the interfering ions are in the other half cell.
You are right, reference doesn't matter.
Hint: note that while you wrote reaction as the one between silver chromate and metallic silver, it is in fact Ag+ that gets reduced, just its concentration near the electrode is controlled by the Ksp of Ag2CrO4.
So, should I consider the Ksp values of the interfering ions with Ag+ and CrO42-
Then the nitrate ion won't interfere since it is highly soluble and will stay in solution. However, the Ksp of S2- and Br- with Ag+ is less than the Ksp of the silver chromate reaction. Does this mean that these ions will mostly form a solid product when interacting with Ag+ effectively interfering with the half-cell reaction?
When considering the cations, could I look at their standard reduction potentials and compare them to Ag+? I see that they are both lower and therefore, the reduction of Ag+ will be favoured, but lead chromate Ksp is also low, and will precipitate some CrO42- out of solution.
So the ions that interfere will be S2-, Br- and Pb2+?
That's what I would expect.
Sorry, no time for more detailed discussion, and I won't be able to read the forum for a week.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
