MHB Which is the geometric interpretation?
The discussion focuses on the geometric interpretations of two transformation matrices. The first matrix represents a 90-degree rotation in the xy-plane with a reversal of the z-direction, while the second matrix corresponds to a -60-degree rotation in the yz-plane. Key properties such as fixed points and kernels are analyzed, revealing that the first matrix does not have a projection due to its kernel containing only the zero vector. The fixed points for the first transformation are along the z-axis, indicating a rotation rather than a reflection or projection. Overall, the transformations are characterized by their rotation properties and the preservation of vector lengths and angles.
mathmari
MHB
Hey! :o
Which is the geometric interpretation of the following maps?
$$v\mapsto \begin{pmatrix} 0&-1&0\\ 1&0&0\\ 0&0&-1\end{pmatrix}v$$ and $$v\mapsto \begin{pmatrix} 1& 0&0\\0&\frac{1}{2} &-\frac{\sqrt{3}}{2}\\ 0&\frac{\sqrt{3}}{2}&\frac{1}{2}\end{pmatrix}v$$
mathmari said:
Hey! :o
Hey mathmari!
Can we think of some geometric properties that we can verify? (Wondering)
For instance, if a map is a projection, we expect that we have fixpoint vectors in a plane and a non-zero kernel, don't we?
For a rotation we would expect a fixpoint vector along the axis, and that the lengths and angles of vectors are preserved.
For a reflection we would expect fixpoint vectors in a plane, and a normal vector that is mapped to its opposite.
Do those maps have fixpoint vectors?
What is their kernel?
Is there a vector that is mapped to its opposite? (Wondering)
We might also characterize the matrices by the eigenvalues and eigenvectors.
For instance a projection in 3D will have eigenvalues 1, 1, and 0.
And a reflection will have eigenvalues 1,1, and -1.
Can we find those? (Wondering)
For the kernel we have: \begin{equation*}\begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 1\end{pmatrix} \ \overset{Z_1\leftrightarrow Z_2}{\longrightarrow } \ \begin{pmatrix}1 & 0 & 0 \\ 0 & -1 & 0 \\ 0 & 0 & 1\end{pmatrix}\end{equation*}
So the kernel contains only the zero vector. Therefore we don't have a projection. For the set of fixed points we have: \begin{align*}\begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 1\end{pmatrix}\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}=\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix} &\longrightarrow \begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 1\end{pmatrix}\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}-\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}=\begin{pmatrix}0 \\ 0\\ 0\end{pmatrix} \\ & \longrightarrow \begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 1\end{pmatrix}\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}-\begin{pmatrix}1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1\end{pmatrix}\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}=\begin{pmatrix}0 \\ 0\\ 0\end{pmatrix} \\ & \longrightarrow \left (\begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 1\end{pmatrix}-\begin{pmatrix}1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1\end{pmatrix}\right )\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}=\begin{pmatrix}0 \\ 0\\ 0\end{pmatrix}
\\ & \longrightarrow \begin{pmatrix}-1 & -1 & 0 \\ 1 & -1 & 0 \\ 0 & 0 & 0\end{pmatrix}\begin{pmatrix}v_1 \\ v_2\\ v_3\end{pmatrix}=\begin{pmatrix}0 \\ 0\\ 0\end{pmatrix}\end{align*}
The echelon form of the matric ist:
\begin{equation*}\begin{pmatrix}-1 & -1 & 0 \\ 1 & -1 & 0 \\ 0 & 0 & 0\end{pmatrix} \ \longrightarrow \begin{pmatrix}-1 & -1 & 0 \\ 0 & -2 & 0 \\ 0 & 0 & 0\end{pmatrix}\end{equation*}
We get the equations
\begin{align*}-v_1-v_2=&0 \\ -2v_2=&0\end{align*}
The set of fixed vectors is therefore \begin{equation*}\text{Fix}=\left \{v_3\begin{pmatrix}0 \\ 0 \\ 1\end{pmatrix}\mid v_3\in \mathbb{R}\right \}\end{equation*}
Is this a fixpoint vector along the axis, and that the lengths and angles of vectors are preserved and so we have a rotation? (Wondering)
mathmari said:
Hey! :o
(1, 0, 0) is mapped to (0, 1, 0), (0, 1, 0) is mapped to (-1, 0, 0), and (0, 0, -1). Geometrically, a three dimensional figure is rotated 90 degrees in the xy-plane and the z-direction is reversed.
$cos(-60)= \frac{1}{2}$ and $sin(-60)= -\frac{\sqrt{3}}{2}$ so this is a rotation by -60 degrees (60 degrees counter-clockwise) in the yz-plane.
Shouldn't the matrix be:
\begin{pmatrix}0 & -1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & {\color{red}-\enclose{circle}{1}}\end{pmatrix}
(Worried)
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 52 ·
  • · Replies 34 ·
