Which Object Has the Greater Instantaneous Velocity?
Object A maintains a constant velocity of 4 m/s throughout the 5 seconds, while Object B starts at 8 m/s and decreases to 0 m/s by the end of the interval. At 5 seconds, Object A's instantaneous velocity is still 4 m/s. In contrast, Object B's instantaneous velocity at 5 seconds is 0 m/s. Therefore, Object A has the greater instantaneous velocity at that time. The discussion clarifies the concept of instantaneous velocity in relation to the specified time.
xPiiNK
A velocity time graph starts from 0-5 s , object A has constant velocity of 4 m/s. Object B has an initial velocity of 8 m/s and constantly decreases and reaches 0 m/s at 5 s. so i need to know what is the instantaneous velocity. Also, which of the object's instantaneous velocity is greater. sorry if this is confusing.
Instantaneous velocity occurs at some specific time. What time are you being asked about?
it asks at time 5 which instantaneous velocity is greater
Welcome to Physics Forums.
Okay, then what is the velocity of A at 5 s?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
