MHB Which Prime Numbers Make p^2 + 1007 Have Less Than 7 Divisors?
The discussion focuses on identifying prime numbers \( p \) for which the expression \( A = p^2 + 1007 \) has fewer than seven positive divisors. Participants analyze the conditions under which the number of divisors of \( A \) can be calculated and the implications of those calculations. The conversation highlights the mathematical approach needed to solve the problem, including divisor counting techniques. The thread concludes with appreciation for insightful contributions, indicating a collaborative effort in problem-solving. This exploration of prime numbers and divisor functions is central to the mathematical inquiry presented.
lfdahl
MHB
Determine all prime numbers $p$ such that the total number of positive
divisors of $A = p^2 + 1007$ (including $1$ and $A$) is less than $7$.
Mathematics news on Phys.org
P cannot be odd
reason if p is odd $p^2 $is 1 mod 8 so $p^2 +1007$ is divisible by $2^3$ so at least 4 *2 or 8 factors
so only candidate to be tested left is p =2
p =2 gives 1011 = 3 * 337 so 4 factor 1,3,337,1011
so only solution p = 2
kaliprasad said:
P cannot be odd
Thankyou, kaliprasad for your participation. Clever answer!:cool:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
