Which Track Will Have the Greater Ball Speed?
The discussion centers on determining which of two tracks, A or B, will result in a ball having greater speed upon reaching the end. Key points include the conservation of energy principle, where potential energy lost translates into kinetic energy gained. It is suggested that if both tracks start and end at the same heights and the balls are released from rest, they should theoretically have the same speed, assuming no friction. However, the varying lengths of the tracks and the potential impact of friction complicate the conclusion. Ultimately, without additional information about friction, the final speeds of the balls cannot be definitively determined.
cutie05
Consider the identical balls released from rest on Tracks A and B as shown. When they reach the right ends of the tracks, which will have the greater speed?
Will The ball on track B will have the greater speed.
There is not enough information to decide.
Both will have the same speed.
The ball on track A will have the greater speed.
Tough to say, since the picture is awaiting approval. The general approach should use the idea that energy is conserved. Any loss of potential energy is compensated for by an increase in kinetic energy. Your change in potential energy is reflected in the change in height (PE = mgh). Your change in kinetic energy is reflected in the change in velocity (KE=1/2 mv^2). If you lose height, the velocity has to increase. If you gain height, the velocity has to decrease.
Since the track lengths are different, you have know about friction. Do you ignore it?
Well, since the tracks both start and end at the same heights, the speed must be the same if they both start at the same speed. Using the potential energy = mgh, and the mechanical energy formula K_f + U_f = K_i + U_i.
You need to know if the track has friction
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
