Which Uses Less Energy: Refrigerator or Freezer for Cooling Water?
  • Thread starter Thread starter Pauli_Pocket
    Cop
A comparison of energy usage between a refrigerator set at +2°C and a freezer at -18°C reveals that the refrigerator is more efficient for cooling water. The coefficient of performance (C.O.P) for the refrigerator is significantly higher at 15.278 compared to the freezer's 6.711. Calculating the work required to cool 250 ml of water from room temperature to +5°C shows that the refrigerator needs approximately 1.0274 kJ, while the freezer requires about 2.3388 kJ. The discussion emphasizes that lower temperature differentials favor refrigeration efficiency, while higher differentials benefit heat engines. Ultimately, the refrigerator uses less energy for the specified cooling task.
Pauli_Pocket
Compare a refrigerator set at +2 oC and a freezer set at -18 oC, both of which are operating in the room with temperature of +20 oC. What is relative amount of electric energy that will need to be used in both cases to cool a cup of water (250 ml) from room temperature to +5 oC? Assume ideal operation of both systems.
C.O.P = Tcold/(Thot-Tcold)
C.O.P = Qc/w
Q = mCΔT
C.O.P (refrigerator) = 275K/(293K-275K) = 15.278
C.O.P (freezer) = 255K/(293K-255K) = 6.711
Q = 250g(4.1855 J/g*K)(278-293K) = -15.696kJ
I would be tempted to say you are almost there and so all you need to do is to apply you second equation (in each case ) using the cop for thereby calculating w since you have worked out the Q cold value.
If I just applied the 3rd equation I would be calculating work in kJ and the amount of work for a refrigerator to cool the water would be lower than for a freezer, which confuses me. Also the problem asks for electric energy in J/s or Watts.
(refrigerator) w = Qc/COP = -15.696 kJ/15.278 = -1.0274 kJ
(freezer) w = Qc/COP = -15.696 kJ/6.711 = -2.3388 kJ
I think the purpose of giving you the info abt the cup of water us to allow you to calculate the energy to be withdraw. You correctly calculated thus as 15.7 kJ. The fridge is more efficient with better cop, so you need just 15.7/15.278 kJ while the freezer needs 15.7/6.711 kJ.
The relationships look ok -- for pumps and refris lower temp differential better, for heat engines the opposite. Finally the qs as you have stated it is asking for energy not power so KJ is correct and not watts.
That's my take anyway.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
