Which way did Newton find F = ma?
  • Thread starter prosteve037
  • Tags
    Newton
In summary, Newton's original works defined force as F\propto ma without any attention to the proportionality constant. This was due to his use of geometric representations rather than numerical values. He was able to determine proportions between objects/parameters, such as the mass and orbit of the Earth and Moon, despite not knowing their exact values. He did not perform a specific experiment to find the relation F\propto ma, but rather deduced it through his observations and calculations.
  • #36
For my understanding of Newton's work, concept of momentum is derived from the concept of centre of mass (momentum it is its derivative over time) and galilean relativity applied to centre of mass. Two-arm levers, scales, etc. devices, leading to concept of centre of mass, were well known even long before Galileo.
Newton made lots of experiments with colliding penduli (different masses, elastic, semi-elastic and inelastic collisions). So he had direct experimental confirmation of momentum conservation (he knew that the angle pendulum reaches is proportional to the velocity at the lowest point if the angle is small). He could easily compare masses and find their proportions and could measure the angles pendulum reaches.
  • #37
So in short, he used proportioning techniques to deduce the formula?
  • #38
Yes, that is what I was trying to tell you long time ago already...
  • #39
Gah sorry. I always did ask more questions than I did listen to answers :/
I should ask though, does the Principia show what Newton was trying to measure when performing his pendulum experiments? What parameter did he use to measure momentum/"quantity of motion"?
  • #40
I rather believe that most of his ideas come from astronomical observations, especially Kepler laws. Pendulum experiments and common experience thought experiments (as well as Galileo's experiments) might help him to extend F~a into F~ma.
Newton did not measure momentum. He measured only proportions between momenta. Even further - not between momenta directly, but proportion between masses (easy with balance or combining several identical weights together) and proportions between velocities - these are in turn proportional to max angle of pendulum (in an approximation of small angles - Newton knew this relation). Measuring angles was pretty simple.
  • #41
Wait... I'm confused.
So if he measured proportions between masses and proportions between velocities, where does momentum come into play?
Wouldn't proportions between masses just be a comparison? And same with velocity?
  • #42
Make two Newtonian penduli (a ball is hung on two cords mounted in two points of the ceiling, to ensure it travels in a plane) - one of some mass, the second of three times bigger mass.
Now deflect the heavier one by some angle (small enough to use sin(x)=x approx) from equilibrium, and lighter one by three times bigger angle. Release both of them simultaneously.
See that after collision they bounce to a maximum angles having the proportion 1:3, although (as the collision was not perfectly ellastic) the angles are smaller than original.
Conclusion: momentum of some body is equal to momentum of another body traveling 3 times slower but weighting 3 times more
  • #44
Are the penduli hitting each other? I assumed they were each colliding with two identical masses/objects (two separate elastic collisions).
Written down in math, would the results look something like this?
[itex]\textit{θ}_{M}\propto{θ}_{m}[/itex] --> [itex]\textit{θ}_{M}\textit{ = c}_{1}\textit{θ}_{m}[/itex] (where [itex]\textit{c}_{1}[/itex] is some constant, in this case [itex]\textit{c}_{1}[/itex] is 3)
[itex]\textit{M}\propto{m}[/itex] --> [itex]\textit{M = }\textit{c}_{2}\textit{m}[/itex] (where [itex]\textit{c}_{2}[/itex] is some constant, in this case [itex]\textit{c}_{2}[/itex] is 3)
[itex]\textit{Mθ}_{m}\textit{ = mθ}_{M}[/itex]
So because the angles and masses shared the same proportion (3), the "amount of motion" that each pendulum contained/generated was the same. I'm going to go ahead and assume that Newton took the thetas and did some math to replace them with the appropriate final velocities (at the colliding points) of the penduli.
Now from this, it seems like Newton just chose a definition for momentum. Because the angular displacements of the proportional penduli after collision would've been equal (two separate elastic collisions), it does make sense that he would've just defined momentum based on the displacement or "amount of motion" of the collided object.
But on what grounds does Newton stand in making such a definition? Just because the "amounts of movement" (displacements) are equal and the products of masses and velocities are equal doesn't mean that the "amounts of movement" are equal to the product of mass and velocity.
  • #45
I hope I don't get penalized for necro-posting :[
But since last post, post I've read some documents on Google that show the thinking of someone from the time around Newton's. His name is William Whewell and he wrote books on the history of "inductive sciences". You can find some of his books on Google Books for free.
In his readings though, he talks about [itex]\textit{mv}[/itex] and how it's not [itex]\textit{m + v}[/itex] because of the units. Still it was simply understood, even at that time (around the 1800s I believe), that the "quantity of motion" is the product [itex]\textit{mv}[/itex].
Was [itex]\textit{mv}[/itex] just defined as the "quantity of motion" of an object because it was the only similar characteristic between two objects in an experiment involving collisions? (I'm referring obviously to the Newton's cradle, or the experiments brought up by xts)
  • #46
I don't know Whewell's books (ok, I'll try to read some...), but,
From the perspective of our discussion 1800 is just yesterday - those were pretty modern times. Newtonian mechanics got reformulated to algebraic form in early 18th century. Whewell wrote his works after analytical mechanics by Lagrange and Hamilton.
Was mv just defined as the "quantity of motion" of an object because it was the only similar characteristic between two objects in an experiment involving collisions?
I believe - yes. Actually, in Whewell's times the other value measuring amount of motion was also used: kinetic energy, having even stranger property: it is preserved in ellastic collisions and in gravitational interactions, but it gots lost in inellastic collisions.
He found that such defined 'quantity of motion' is always preserved in isolated systems, so it may be very useful to formulate laws of motion.
Yes and no. He knew that maximum velocity of the pendulum is proportional to maximum deflection angle (for a given pendulum length). But he didn't care about expressing the velocity in our modern terms (m/s or inches per second). It is yet another case, where Newton, in his euclidean approach, was focused on proportions, but not on the actual numeric values. So (you did it wrong!) he could go one step further: [itex]
\theta_M/\theta_m = m/M\quad\Longrightarrow\quad
v_M/v_m=m/M[/itex] but he never did the next step: [itex]v_M/v_m=m/M\quad\Longrightarrow\quad Mv_M=mv_m[/itex] - because for him it made no sense to multiply ounces by something else than pure number. It was also a reason why Newton never mentioned any numerical values of velocity: he could define it as a 'change of position (in time)', but he had no unit to measure it. He could measure the angle, but not the velocity: it was not only technical problem, but he lacked units of measure. He could measure angles (in degrees), but he had no unit for velocity. The idea of 'metre per second' (or rather feet per second) came 50 years later.
  • #47
I agree with your sentiment here, but not your dates. Have you tried reading physics texts written in the early 1800s? Physics then was quite different from the classical physics of today. Physics was rewritten from the ground up twice during the 19th century, first by Hamilton (born 1805) and then again by Gibbs and Heaviside in the latter part of the century. The modern notation of Newton's second law, [itex]\vec F = m\vec a[/itex], dates to the late 19th century.
And that in a sense is an answer to the key question raised in this thread, "Which way did Newton find F=ma?" He never did. To say that he did do so is in a sense a case of historical revisionism. Newton's formulation was highly geometric in nature. A rudimentary form of an algebraic interpretation of Newtonian mechanics didn't appear until several decades after Newton's death. It took another 200 years to arrive at the clean formulation of Newtonian mechanics as it is taught today. In the interim, mathematics and physics were rewritten from the ground up, multiple times.
This is typical of mathematics and science. There is a dirty little secret that underlies much of math and science: The all wrapped up with a bow picture of science that is presented to students took a long time to formulate. The initial formulations, while brilliant and revolutionary, were typically crude, clumsy, and incomplete. Newtonian mechanics is a good example of this cleanup process and after-the-fact presentation.
Regarding Newton himself, John Maynard Keynes said it best: "Newton was not the first of the age of reason. He was the last of the magicians." Some of Newton's work and reasoning are lost forever, some are in diaries and notebooks (many of which Keynes collected and later donated to science historians) that are only recently being transcribed. Does it really matter how exactly Newton came up with his laws of physics? His way of thinking was quite foreign to ours. He was limited by the mathematical tools available at his time and he was hobbled a bit by his rather antiquated views of the world. His views were a bit antiquated even by the standards of his time; he truly was the last of the magicians. And he truly was one of the greatest physicists of all times.
  • #48
prosteve037 said:
I was under the impression that Newton deduced
[itex]\textit{F}\propto{m}[/itex]
[itex]\rightarrow[/itex] [itex]\textit{F = k}_{1}\textit{m}[/itex]
where in SI Units they would be in the form
[itex]\textit{F = ma}[/itex]...
how did he resolve that [itex]\textit{k}_{1}[/itex] is dependent on acceleration and/or that [itex]\textit{k}_{2}[/itex] is dependent on mass?
if you read the original Latin formulation of the second law
Lex II: "mutationem motus proportionalem esse vi motrici impressae": "change of motion is proportional to applied force",
you'll see that all interpretations are not true: Newton deduced only the obvious principle that the effect is proportional to the cause,
[itex]\textit{v}\propto{F}[/itex], and then he explains it (if a force generates a motion, a double force generates double the motion, a triple ...).
Mass was not considered, as gravity was the only known force at the time, and its effect is not influenced by mass.
The key point is that to the Latin word "motus" [redundantly] correspond English "motion", and "speed", "velocity", and corresponds also [Defintion II: "quantitas motus" = "quantity of (matter and) motion"] "momentum".
Finally, to make things worse, we must remember that "quantitas motus" for Newton [ mv = E k ] was also the value of Kinetic Energy, and that
KE [is proportional to squared speed] = mv² was introduced only subsequently by Leibniz (vis viva).
[This is true even now, if we consider that KE = m[=1]v² [itex]\frac{1}{2}[/itex] J [= (m=2 * 1 m/s)]
This should be the staring point for the discussion
  • #49
prosteve037 said:
I was under the impression that, by experiment, Newton deduced
[itex]\textit{F}\propto{m}[/itex] [itex]\rightarrow[/itex] [itex]\textit{F = k}_{1}\textit{m}[/itex]
(where [itex]\textit{k}_{1}[/itex] is some constant)
and
[itex]\textit{F}\propto{a}[/itex] [itex]\rightarrow[/itex] [itex]\textit{F = k}_{2}\textit{a}[/itex]
(where [itex]\textit{k}_{2}[/itex] is some constant)
and then found that either/both
[itex]\textit{k}_{1}\propto{a}[/itex] [itex]\rightarrow[/itex] [itex]\textit{k}_{1}\textit{ = c}_{1}\textit{a}[/itex]
(where [itex]\textit{c}_{1}[/itex] is some constant)
and/or
[itex]\textit{k}_{2}\propto{m}[/itex] [itex]\rightarrow[/itex] [itex]\textit{k}_{2}\textit{ = c}_{2}\textit{m}[/itex]
(where [itex]\textit{c}_{2}[/itex] is some constant)
thus creating
[itex]\textit{F = c}_{1}\textit{ma}[/itex]
and/or
[itex]\textit{F = c}_{2}\textit{ma}[/itex]
However, I've read in some other forums how Newton actually meant
[itex]\textit{F}\propto{ma}[/itex] [itex]\rightarrow[/itex] [itex]\textit{F = kma}[/itex]
Which is the case? Did he use the first method or did he simply state the second?
If he did use the first method, how did he resolve that
I read in some place that he did experiments with masses and densities and that used that data to study Jupiter motion and tests his hypothesis. Sorry by not being of more help.
  • #50
I think you're short changing Newton here.
He specifically defines momentum (calling it "quantity of motion) in defintion II. It's completely clear he understands it is the product of the mass and velocity.
Thereafter almost every time he uses the word "motion" it is short for "quantity of motion". He drops the "quantity of" apparently just for convenience. When he has to refer to motion as we understand it today, he usually qualifies it as "motion in a right line".
From wiki:
"History
Newton's original Latin reads:
Lex II: Mutationem motus proportionalem esse vi motrici impressae, et fieri secundum lineam rectam qua vis illa imprimitur.
This was translated quite closely in Motte's 1729 translation as:
Law II: The alteration of motion is ever proportional to the motive force impress'd; and is made in the direction of the right line in which that force is impress'd.
According to modern ideas of how Newton was using his terminology,[26] this is understood, in modern terms, as an equivalent of:
The change of momentum of a body is proportional to the impulse impressed on the body, and happens along the straight line on which that impulse is impressed."
http://en.wikipedia.org/wiki/Newton's_laws_of_motion
That last translation is not a retroactive "clean up" of the type DH refers to in his excellent post. It is actually what Newton was saying. Here is the Law with it's explanation/discussion:
"The alteration of motion is ever proportional to the motive force impressd; and is made in a direction of the right line in which that force is impressed.
If any force generates a motion, a double force will generate double the motion, a triple force triple the motion, whether that force be impressed altogether and at once, or gradually and successively. And this motion (being always directed the same way with the generating force), if the body moved before, is added to, or subtracted from the former motion, according as they directly conspire with, or are directly contrary to each other, or obliquely joined, when they are oblique, so as to produce a new motion compounded from the determination of both."
The clause "whether that force be impressed altogether and at once, or gradually and successively" demonstrates that Newton understood the concept of impulse, without having a dedicated term for it.
A big hindrence in deciphering the Principia is the fact it wasn't written as a physics text aimed at the uninitiated. It was directed toward whatever people there were with enough physics education to be in, or interested in, the activities of the Royal Society, as is evident from passages like this:
"By the same, together with the third Law, Sir Christ. Wren, Dr. Wallis, and Mr. Huygens, the greatest geometers of our times, did severally determine the rules of the congress and reflexion of hard bodies, and much about the same time communicated their discoveries to the Royal Society, exactly agreeing among themselves as to those rules. Dr. Wallis, indeed, was something more early in the publication; then followed Sir Christopher Wren, and lastly, Mr. Huygens. But Sir Christopher Wren confirmed the truth of the thing before the Royal Society by the experiment of pendulums, which Mr. Mariotte soon after thought fit to explain in a treatise entirely upon the subject."
I think this explains why he does things like drop "quantity of" from "quantity of motion". He's pretty sure his intended audience will all have come to take the word "motion" to refer to "quantity of motion" unless otherwise qualified, from their familiarity with all the papers about and experiments concerning, conservation of momentum. The Principia comes down to us out of context.
Incidentally, Newton doesn't appear to take any credit for any of the three laws, that I can see. He ascribes the first two to Galileo:
"Hitherto I have laid down such principles as have been received by mathematicians, and are confirmed by abundance of experiments. By the first two Laws and the first two Corollaries, Galileo discovered that the descent of bodies observed the duplicate ratio of the time; and that the motion of projectiles was in the curve of a parabola…"
and the third seems to have arisen (though I'm not sure) from the collective endeavor to prove conservation of momentum he described above.
  • #51
zoobyshoe said:
... you're short changing Newton ...
In Newton's words, zoobyshoe," hypotheses fingis": you are imagining things. What Newton says is clear: you are fantasising about "what he dropped", "when he dropped" and even "why he dropped". You reverse the historical facts : somebody applied, later, "momentum" to what Newton referred to as quantity of motion [measure of the same arising from velocity and quantity of matter]. And that "almost" gives you the power of deciding what suits you when it suits you. [and you cite "wiki" (!) as your authority]
[bold added]
He defines momentum "quantity of motion"... Thereafter almost every time he uses the word "motion" it is short for "quantity of motion"... for convenience. From wiki: "According to modern ideas this is understood, in modern terms, as an equivalent of:..."
But all your effort is not necessary if you read, carefully, what I said: for Newton everything was simple because he considered [as it is right] "motus" as one concept. "motion, speed, velocity, momentum" are redundant distinctions as there cannot be speed without direction nor velocity without mass, do you realize that? and cannot be matter without quantity : "pears" must be "quantity of pears", moreover there was no reason, then, to take mass into account.
It was even better for him, fabulous, because he naively thought that both Energy and velocity/momentum are proportional to force: Fg → Ek→ v,p
logics said:
[itex]\textit{v, [p, E]}\propto{F}[/itex]
The big problems arose later, when Leibniz' theory was verified and it was accepted that E = v².
Why is it a problem for you to admit that his original formulation was re-formulated, adapted to subsequent ideas? is there anything wrong, is that something to be ashamed of? The question is only if that was a good or a bad decision.
  • #52
logics said:
in Newton's words "zoobyshoe, hypotheses fingis": you are imagining things. What Newton says is clear: you are fantasising about "what he dropped", "when he dropped" and even "why he dropped". You reverse the historical facts : somebody called, later, "momentum" what Newton referred to as motion and matter. And that "almost" gives you the power of deciding what suits you when it suits you. [and you cite "wiki" (!) as your authority]
[bold added]
I don't have to hypothesize about his shortening of the term, because I can read:
"Definition II
The quantity of motion is the measure of the same arising from the velocity and quantity of matter conjunctly.
The motion of the whole is the sum of all of the parts; and therefore in a body double in quantity, with equal velocity, the motion is double; with twice the velocity, it is quadruple."
He defines "quantity of motion" and then, right away, drops the "quantity of" in explicating it. It's obvious from the relationships he describes he's still talking about "quantity of" motion: momentum.
"Quantity of matter" is mass, which he defines in definition I.
Paraphrased:
"Momentum arises from velocity and mass.
The momentum of the whole is the sum of the vectors. If you double a mass but keep the velocity the same, its momentum will be doubled. If you then double the velocity the momentum will be quadrupled."
If you read the definition carefully you will notice he suddenly drops "quantity of" and uses the word "motion" by itself to refer to what we call "momentum". If you happen to miss that, the rest of the Principia will sound like gibberish, because he drops "quantity of" almost everywhere else when he's referring to momentum. There, again, though, it's always clear from the relationships he's describing he's referring to momentum.
Here's another example where he begins by speaking about "quantity of motion", but then drops "quantity of" in explicating his subject:
"The quantity of motion, which is collected by taking the sum of the motions directed towards the same parts, and the differences of those that are directed to contrary parts, suffers no change from the action of bodies among themselves.
"For action and its opposite reaction are equal, by Law III, and therefore, by Law II, they produce in the motions equal changes toward contrary parts. Therefore if the motions are directed towards the same parts, whatever is added to the motion of the preceding body will be subducted from the motion of that which follows; so that the sum will be the same as before. If the bodies meet with contrary motions, there will be an equal deduction from the motions of both; and therefore the difference of the motions directed toward opposite parts will remain the same..."
I do not believe I am fantasizing that this is an explanation of conservation of momentum. If Newton were generally waving his hand simultaneously in the direction of "motion, speed, velocity, momentum", as you claim, how could he accidentally end up understanding and specifically describing conservation of momentum here?
As I said, when he means motion as 'displacement in space' he almost always qualifies it such that you understand that's what he means, by saying, for example: "uniform motion in a right line".
I am not aware he ever spoke about energy, and he certainly wasn't confused about the difference between velocity and momentum:
From Law III:
"If a body impinge upon another, and by its force change the motion of the other, that body also (because of the equality of the mutual pressure) will undergo an equal change, in its own motion, toward the contrary part. The changes made by these actions are equal, not in the velocities but in the motions of the bodies."
Notice he says "...not in the velocities..."
(All my quotes of Newton come from here: http://www.archive.org/stream/Newtonspmathema00newtrich#page/n77/mode/2up)
  • #53
zoobyshoe, where would/do you say this understanding arises from? The previously posted proportioning approach? Or the simpler/concise way that Whewell approached it?
So because the concept of momentum was considered long before energy, can we just disregard any connection between the formulation of [itex]\textit{mv}[/itex] and the concept of kinetic energy? I just don't want to dive into a whole different concept and focus on momentum :P
Also, it's very interesting that you said that Newton never thought it would be reasonable to multiply two different kinds of values together (like ounces to meters per second as you said). I read somewhere else that he gave a name to this idea of his and named it something like the Principle of Similitude or something...
Anywho, it seems that we have a conflicting argument here in terms of zoobyshoe's post and xts'. From what I can see, (and please correct me if I'm wrong) while xts says that Newton had no clear-cut mathematical definition for momentum ([itex]\textit{mv}[/itex]) zoobyshoe is saying that Newton knew full well that momentum had to be [itex]\textit{mv}[/itex] (Hence why I ask zoobyshoe about his view on how Newton came to see it this way).
  • #54
I've greatly enjoyed all of xts' posts in this thread and wouldn't want to think there was any conflict.
My reasoning goes like this: given the proportional relationships he described, he couldn't be talking about anything other than momentum when he uses the term "quantity of motion".
Definition II
The only relationship where doubling the mass but keeping the velocity the same results in a doubling of an unknown third thing (quantity of motion?) is multiplication. If that statement ( "in a body double in quantity, with equal velocity, the motion is double") is true, he must have arrived at the original (undoubled) "quantity of motion" by multiplying the mass times the velocity. Addition, subtraction, division would not result in the same conclusion.
You may well ask what units of mass and velocity he would have used. He wouldn't need fixed units, just "parts". 2parts mass times 3parts velocity = 6parts motion. Let's double the mass: 4parts mass times 3parts velocity = 12parts motion. The relationship: "in a body double in quantity, with equal velocity, the motion is double" holds true. To find how many "parts" a mass has he has to compare it to another mass. If mass A is twice mass B (a fact he could discover by weighing them) then mass A is two parts of mass and mass B is one part of mass. The same holds for velocity. Given any two pendula he can describe the mass or velocity of both in terms of the number of "parts" they sum up to. One will have so many "parts" of the total mass or velocity, and the other will have what's left over of the total.
All that being the case, he could well have said, "quantity of motion is collected by multiplying the number of parts of quantity of matter by the number of parts of velocity".
Following his logic requires squarely facing what xts asserted earlier:
xts said:
At Newton's times proportionality was perfectly known and understood - it was used even more frequently than nowadays. Just contrary - those times the numerical values, measurement units, etc. were rather neglected. It was the effect of geometrical representation. As in Euclid "Elements" - the line segment represent the value, and twice longer section represent twice bigger value, but no one cares to say that 1 inch on the drawing represents 1 pound of mass. You may make the same Euclidean construction in different scale, and all conclusions will be the same.
Such approach is really difficult to understand for modern people, who learn on numbers, rather than on Euclodean constructions.
Newton was one of the very last scientists using such geometrical representations (but it was common till his times, Copernicus did the same). It was 18th century when numerical approach (started by Rene Descartes even a bit earlier than Newton worked) finally won popularity.
I would add that Galileo worked everything out geometrically, as well.
Descartes was new. I am currently reading a bio of Newton in which the author asserts that the concept of Cartesian coordinates was vital to Newton in the development of his "fluxions", which would put him in the vanguard of those who caused the shift of emphasis from geometry to algebra.
So because the concept of momentum was considered long before energy, can we just disregard any connection between the formulation of mv and the concept of kinetic energy?
As far as I can see Newton worked everything out in terms of conservation of momentum, and there's no indication so far in my reading that kinetic energy will be brought into it.
  • #55
I have read that Newton worked out his mathematics using algebra, analytic geometry, and calculus, then translated it all to the then-more-familiar geometry so it could be understood and accepted.
  • #56
"Citation needed."
  • #57
D H said:
"Citation needed."
By the help of the new Analysis Mr. Newton found out most of the Prepositions in his Principia Philosophiae: but because the Ancients for making things certain admitted nothing into Geometry before it was demonstrated synthetically, he demonstrated the Propositions synthetically, that the System of the Heavens might be founded upon good Geometry. And this makes it now difficult for unskilful men to see the Analysis by which these propositions were found out.
--- Sir Isaac Newton, 1715
Our specious algebra is fit to find out, but entirely unfit to consign to writing and commit to posterity. -- Sir Isaac Newton, 1694.
  • #58
Newton is talking about himself in the third person here? What's this quote from? A letter? A publication of the Royal Society?
  • #59
Third person, yes. A letter. You can easily find this and all of his letters online. He also wrote that algebra was for "bunglers."
  • #60
Any way you could just link me to these two letters?
It surprises me because he refers to himself in the first person in the Principia.
  • #61
For anyone who still doubts Newton understood that momentum was the product of mass times velocity, I found a passage where he directly says it is:
...we are to take the product (if I may so say) of the body A, by the chord of the arc TA (which represents its velocity), that we may have its motion in the place A immediately before reflexion; and then by the chord tA, that we may have its motion in the place A immediately after reflexion. And so we are to take the product of the body B by the chord of the arc Bl, that we may have the motion of the same immediately after reflexion. And in like manner, when two bodies are let go from different places, we are to find the motion of each, as well before as after reflexion; and then we may compare the motions between them, and collect the effects of reflexion.
http://www.archive.org/stream/Newtonspmathema00newtrich#page/n95/mode/2up Page 91
Terminology: I've already demonstrated the word "motion" is to be understood as "momentum".
"Body" means "mass", which we learn from the very first definition:
It is this quantity that I mean hereafter everywhere under the name of body or mass.
The chord that represents velocity is a chord drawn from the point to which you pull the pendulum back before you let it go, to its bottom dead center position. The length of that chord represents the magnitude of the pendulums velocity when it is going fastest i.e. when it is swinging through that bottom dead center position. Newton says this is well known,
For it is a proposition well known to geometers, that the velocity of a pendulous body in the lowest point is as to the chord of the arc which it has described in its descent.
http://www.archive.org/stream/Newtonspmathema00newtrich#page/n95/mode/2up Page 90
So, by saying that the momentum is the product of the mass times the velocity (or vectorial representation of the magnitude of the velocity) he is saying ρ=mv.
  • #62
Thanks for the direct links zoobyshoe! Great post! :]
So then did Newton identify the "unknown third thing" as the quantity of motion because there was no other similar quantity between the two?
I just wanted to explicitly clarify because you used "unknown third thing" as if to indicate that Newton merely declared this unknown third quantity as a body's quantity of motion, without noting the comparability between two bodies with said attributes (1 body w/ double the mass of the other, equal velocities).
I think it's safe to assume though, that what you're saying is what I was inferring; that Newton knew that the only thing that the two bodies had in common were their mass-velocity products, which had to denote the bodies' quantities of motion.
Are these "parts" of a whole, intrinsic to each? Or are they treated as being synonymous to units?
  • #63
No, the third thing is not unknown to Newton, it is unknown to us. We are trying to decipher Newton's use of language, because there's a confusing mystery. He shifts from speaking of "quantity of motion" to just speaking about "motion". We start out with a list of three known things: mass, velocity, quantity of motion. Suddenly he says "motion", and not "quantity of motion". The word "motion" now becomes an unknown third thing. Unknown to us, not Newton. It could well be he's now referring to a different concept. Maybe, for example, he's shifted to make a point about displacement in space. Its meaning is, for the moment, unknown to us. Its an "unknown third thing", unknown to us, that is. How do we figure out what it might mean? We look at the relationship he describes, and which he now calls by the word "motion" and we realize he's still talking about "quantity of motion". The word "motion", therefore, in the context of the Principia, can often be understood as short for "quantity of motion".
That's important to realize if someone wants to read the Principia. When you read the word "motion" you should always suspect he means "momentum", and try that meaning out to see if it fits the context in which it's used. Rule of thumb: when he does not mean momentum he almost always qualifies the word "motion" with something like "uniform motion in a right line".
At any rate, my post #61 supercedes all previous posts because it reports my discovery of a passage where he directly says "motion" (momentum) is the product of mass and velocity.
What he knew, and what exited him, was that the mass-velocity product was a conserved quantity. He didn't discover this, it was an insight that arose from the experiments with pendulums of the members of the Royal Society:
By "the rules of the congress and reflexion of hard bodies" he means "conservation of momentum in elastic collisions". Newton repeated many of those experiments himself with many different pendulums of different lengths and different materials.
Not sure what you're asking. Do this: make a mixture of 2 parts water to 7 parts flour by volume. You may literally do this or do it as a gedanken. If you're at a loss as to where to start, then let me explain that "parts" is short for "equal parts". Since I specified that the parts must be equal in volume (as opposed to say, weight), the recipe is asking for two volumes of water to be mixed with 7 volumes of flour. What "volume" do you use? The recipe doesn't say. The only stipulation, which is an implicit one, is that you use the same volume for each "part". If you use a "cup" you use that same cup to measure out all the parts. You fill it up once with water, pour that into your mixing bowl, then you fill it again with water and pour that into your mixing bowl. There's your two "parts" of water. Do the same with the same cup for the flour, but do it 7 times. There's your 7 "parts" of flour. You could do the same thing using a teaspoon as your volume, or you could use a 55 gallon drum as your volume. The proportion of equal parts is what matters.
So, that being explained, I don't know how to link it to the particular questions you asked.
  • #64
I think I may have inquired the wrong question to you through my last post :P Apologies!
I understand and agree with your argument from your post completely. However, I feel I may have unintentionally steered attention away from my main, underlying question; regarding how [itex]\textit{mv}[/itex] was declaratively chosen to be the definition of momentum.
With that said I did ask you and xts about your thoughts on this, namely on your opinions of the method by which [itex]\textit{mv}[/itex] was conceptualized (either through proportioning techniques or the "simpler logic" I referred to in an earlier post). From what I understand, the consensus so far (between xts, you, and I) is that, yes, [itex]\textit{mv}[/itex] was conceived through a simpler logic. Now I guess the next "section" to my question is "What were the steps taken in this 'simple logic'?".
I've read that Descartes was the one to propose [itex]\textit{mv}[/itex] as a quantity for motion, having reasoned that 2 bodies with masses [itex]\textit{m}[/itex] and [itex]\textit{2m}[/itex] and respective velocities [itex]\textit{v}[/itex] and [itex]\textit{2v}[/itex], will move another body the same amount. And following the reasoning you described, multiplication would be the only appropriate operation in which this holds.
With all that said, I hope we're on the same page :smile:
Again, in regards to your post zoobyshoe, I never meant to ask on the context of "quantity of motion"/"motion" and I'm sorry if that confused you or anything :P
  • #65
OK. Yes, I did not understand what you were asking.
Looking back through the thread I find you asking for an explanation of where p=mv comes from to begin with. In other words, who first looked at motion and decided there was an important aspect of it different from mere mass at a given velocity, not just mass + velocity, but mass x velocity.
I don't know. No one is credited with this in the Principia. The wiki article on momentum says it was a notion that cropped up here and there throughout history without taking root or leading anywhere till Newton wrote it down. My guess is that specifically focusing on it as an important concept arose from the combined experiments and papers of the members of the Royal Society who experimented with pendulums before Newton. Newton defines it confidently, and fairly briefly, in his opening definitions, almost as if he takes it to be self evident.
Most physics texts introduce you to it the same way. It's pretty much evident that, given two masses at the same velocity, the larger will have more of something important. Likewise it's evident that the difference between throwing a bullet at someone and shooting it at them is drastic. Somehow that difference has to be quantifiable, measurable. I'm betting we'd find a detailed discussion of that in the works of Wallis, Wren, or one of the other pendulum experimenters Newton names.
So, 10 kgs at 10m/s = 20kgs at 5m/s = 50 kgs at 2 m/s. It is a proportional consideration, and the realization it is conserved is really what makes it important.
  • #66
Yes, thank you. This was the kind of reply that I was hoping to see :smile:
Though it's not what I wanted to hear, I agree that the topic was vaguely put forward as if it was indeed self-evident.
I Google'd to see if I could find any documents or readings on the matter involving Wren, Huygens, and Wallis and found a book that hinted at the location of [itex]\textit{mv}[/itex]'s origin.
If you click the hyperlink you can see where it says this, at the bottom-left side of the page. It hints that the 1669 issue of Philosophical Transactions of the Royal Society may have the works/writings of the pendulum experimenters' findings.
Naturally I looked for an English translation of this issue, but sadly to no avail. I was only able to find the original Latin version. :frown: https://docs.google.com/open?id=0B8alG534jxFGYzBlNjAxMWEtZDg1NC00YTc3LTgyYzMtM2ViNjljZDUwYWI2's the segment of the issue that Huygens wrote if anyone wants to see it. There you can see a demonstration of the geometric methods that were used for calculations.
It would be great though if an English translation of this publication was available. That or if there was an article that explained the formula's origin more thoroughly :P
  • #67
Excellent. I'm glad we're now on the same page.
I read the whole chapter of that book and it looks like a great history of the subject of momentum. It's very interesting to me that William of Occam, of Occam's Razor fame, was one of the early contemplaters of the subject. It's clear that Descartes got closest to our present understanding before the Royal Society took it up and, collectively, made all the final corrections. Newton received and reports it as a vector quantity, and not a Cartesian scalar. Your book also restores some credit to Hooke for his experiments, credit that Newton expunged from the Principia in his recap of the Societies' research (which I quoted earlier). Your book, by the way, relates that Huygens, at the same time, but independently of the rest, began to work out the concept of conservation of energy, which should be of interest to you because you seem to favor analyzing things that way if possible. I wonder if you haven't already read forward into the chapter on conservation of energy to see how that played out.
I took latin in high school over 35 years ago and took a stab at this with a Latin-English dictionary. I have just forgotten too much, though.
I can tell you that the first part of that article is a tedious history of who in the society made what contribution when to the experiments and the understanding. Then we get down specifically to Huygen's Regulae de Motu Corporum ex mutuo impulsu - "Rules of the Motion of Bodies after striking against each other" (I'm pretty sure).
Rule #1 seems to be: "If a hard body runs into any other equal hard body at rest, that hard body will come to rest after contact and, at the same time, however, the one that was at rest will acquire the speed of the one that struck against it."
That is the only one I'm reasonably sure of. All the rest have elements I'm not sure how to tackle, so I'm only grasping fragments.
You're quite right that the chart is a geometric analysis. Fusing the fragments of the explanation I could make out with what I learned of their methods from Newton, I see that each line represents a specific, illustrative case of an interaction between two bodies designated A and B. The speed of body A is always represented by the length of the segment AD and segment BD the speed of body B (There's some discussion of different cases this applies to, but I can't sort it out. Vel...vel seems to mean "either...or"). Point C in each case, represents the "center of weight" (centrum gravitatis) of the two bodies. (In other words, the lengths of segments AC and BC represents the relative proportions of their masses.) With points A, B, C, and D established, he introduces a point E. Point E is always relative to point C, such that segment EC will be equal in length to segment DC (if you look down the chart you'll see EC is always equal to DC in length, though it's hard to sort that out in some cases because the label E or D is crowded right together with A or B, the points coinciding, I guess.) Segments AE and BE, are the results it was intended to find, the final speeds of A and B: "I say: EA has (represents) the speed of body A after collision, EB that of body B..." The final direction is also indicated, but I can't make out exactly how.
I know a girl who is a medieval scholar who reads Latin (expert level: she teaches medieval studies at UCLA). Unfortunately she is on and extended tour of Russia and Eastern Europe, and I'd rather wait till she gets back before I show this to her. In the meantime, I might dig someone else up who can certainly do a better job than me.
I accidentally and incidentally ran across another interesting tidbit which says something about the history of Newton II as he actually wrote it vs. F=ma, which I'll post later.
  • #68
Force was not derived. It is a new quantity, and F=kma or F=ma will not
make any difference to solving mechanics or work energy or anything
for that matter because Force being the most fundamental. Work, Power,
Impulse etc etc are derived from force. You can re-create whole mechanics
with F=kma as much as you can create with F=ma.
  • #69
Great post, this was immensely helpful and informative! Thanks a bunch zoobyshoe! :biggrin:
Well I've been digging deeper since my last post and I think I'm finally getting warmer and warmer to a (possibly) definite answer.
In accordance with your post, this says that Descartes had introduced the modern notion of momentum, basing his theory on the context of collisions.
However it also shows (pg. 105) what Galileo had written before Descartes, saying how the weight × velocity of one body is equal to the weight × velocity of another body in a certain case. Algebraically:
[itex]\textit{p = }[/itex] Weight
[itex]\textit{v = }[/itex] Velocity
[itex]\frac{p_1}{p_2}\textit{ = }\frac{v_2}{v_1}[/itex] → [itex]\textit{p}_1{v_1}{ = p_2}{v_2}[/itex]
I don't understand exactly what case this pertains to as it is vaguely stated in the book; the book says that it pertained to a specific case regarding an "oscillating balance" (pg. 106). It is also noted too that Galileo's definition of momentum is quite confusing since he uses momentum, power, and force in the same context :P
I think it's important to realize here too that Galileo was the first to declare the quantity "[itex]\textit{pv}[/itex]" as the representation of a body's quantity of motion. This, to me, is fundamental because although the relation was only present in the specific case of equilibrium (with the "oscillating balance"), he was able to logically deduce that this quantity "[itex]\textit{pv}[/itex]" must represent the only similar property between the two bodies involved; their "quantities of motion", as defined by Galileo. Though it's obviously not [itex]\textit{mv}[/itex], it's the first fundamental step that was taken in the right direction.
With that said, I think it's safe to say that Galileo's conception of "quantity of motion" was either ill-defined, proven right with the wrong experiment, or a combination of the two. Though he had a formula created, what exactly was he trying to measure? This is unclear, but I'm sure if I understood the context of his formulation with respect to the experiment and the data he collected, the formula would make sense.
At the same time, however, I think Galileo was the one who completed all the required algebra (assuming he used algebra) needed to arrive at the correct quantification of motion; he was just measuring in a context outside of collisions (it says on pg. 106 that momentum was viewed in the context of collisions only after Descartes).
What are your thoughts on this, zoobyshoe? :smile:
  • #70
You're very welcome!
Allow me to read that link over a few times and cogitate.
In the meantime, this is the tidbit I found that I thought was interesting:
I picked up a book of Poe stories last week. In one of them, The Purloined Letter, one of the characters is trying to analyze the limits of the intelligence of the Police detective he's just spoken with. He draws an analogy between a massive body and the policeman's mind:
"The principle of the vis inertiae, for example, seems to be identical in physics and metaphysics. It is not more true in the former, that a large body is with more difficulty set in motion than a smaller one, and that its subsequent momentum is commensurate with this difficulty, than it is, in the latter, that intellects of the vaster capacity, while more forcible, more constant, and more eventful in their movements than those of inferior grade, are yet the less readily moved, and more embarrassed, and full of hesitation in the first few steps of their progress."
What I noticed right away is that this character speaks of the overcoming of inertia as resulting in momentum, rather than acceleration. The story was written in 1844, over a hundred years after Newton's death. It's likely Poe's formal education in mechanics happened during his brief time at West Point, around 1830-31, which means, at that time (a hundred years after Newton), Newton II was not yet generally identified as F=ma. It was still being taught as Newton wrote it. I'd like to find out when the transition started and when we could consider it complete.
