Whirling Rope - Find the Tension at Position r
In summary, the question asks for the tension in a uniform rope of mass M and length L, pivoted at one point and whirling with uniform velocity ω. The centripetal force at a given radius r is equal to -mrω^2, and this force is supplied by the tension in the rope. To find the tension at a given radius, we must integrate all the forces for all the dr elements of the rope beyond that radius. By dividing the rope into infinitely many pieces, we can calculate the mass of the rope beyond r, which is equal to μ(L-r), where μ is the mass per unit length. We can then use this expression for mass to calculate the centripetal force required for an element dr at
Astrum
269
A uniform rope of mass M and length L is pivoted at on point and whirls with uniform velocity ω
What is the tension at the rope at r from the pivot point? Neglect gravity.
Centripetal force at r is given by [itex]-mr \omega^{2}\hat{r}[/itex]
I don't know where to go from here, some pointers might be nice.
The tension in the rope supplies the centripetal force for the part of the rope beyond r.
Yes, but that doesn't really help me. I have no idea how to set this up mathematically.
What's the first step? tension is equal to centripetal acceleration here. centripetal force is equal to -mrω^2
We need to find m, at point r. If you divide the rope into infinitely many pieces, m will equal 0 for point r, so that's not the right way.
It means you have to add up (i.e. integrate) all the forces for all the dr elements of the rope beyond r.
μ = M/L - mass per unit length
∴ m = μ (L-r)
∴ m = μ (L-r)
How is that useful?
The mass is the only unknown quantity.
The rope as a whole is mass M. You've given the formula for the mass beyond a given radius, but how are you proposing to turn that into an expression for the tension at a given radius?
Sure, but it's not quite trivial to get that from the mass of that portion. Seems to me that it's easier to do the right integral in the first place.
So, I believe I've solved it, not sure WHY it's correct.
I did the following:
[tex]m_{r}=\frac{L}{r}m_{t}[/tex]
[tex]v_{c}=r\dot{\theta}\hat{\theta}=L\dot{\theta}= \omega[/tex]
Now we have the following function for centripetal force on r: [tex]-\frac{L}{r}m(r\frac{\omega}{L})^{2}[/tex]
Because the centripetal force is a function of r, we integrate with respect to r and get: [tex]-m\frac{(\omega)^{2}r^{2}}{2L}[/tex]
My book got the same answer, but through a way that I don't get. Is this approach bad, or incorrect?
And why exactly is the centripetal force at r not equal to: [tex]-\frac{L}{r}m(r\frac{\omega}{L})^{2}[/tex]
I can't follow that logic because I don't know what all your variables mean, but you ended up with the right expression for the centripetal force required for an element dr at radius r (except that you left out the dr itself).
That cannot be right since it reaches max magnitude at the far end of the rope. You've left out the constant of integration.
Why do you think it should be that? (You've left out a distance factor somewhere; dimensionally that would be MT-2).
Pull out all the constants and integrate.
[tex]-m\frac{\omega^{2}}{L}\int r dr [/tex]
= [tex]-m\frac{(\omega)^{2}r^{2}}{2L}[/tex]
From what I understand, the final function should be the centripetal force of all pieces of the rope up to, and including, r.
[tex]-\frac{L}{r}m(r\frac{\omega}{L})^{2}[/tex] - I thought this might be the centripetal force for r, because it has the same form as the general equation for centripetal force in polar coordinates, which is (if motion is only in the [itex]\hat{\theta}[/itex] direction: [tex]\vec{F}_{c}=m(r(\frac{d \theta}{dt})^{2}\hat{\theta})[/tex]
What is the range of that integral?
No, from r and beyond.
It cannot be because it is dimensionally wrong. Where does 1/r in front come from?
Sorry, the code was acting funny, the range is [r,o], so the constants cancel, and we're left with:
[tex]-m\frac{(\omega)^{2}r^{2}}{2L}[/tex], is that not so?
And why do you say it's the force from r and beyond? We're only adding up the pieces to r.
The (1/r) came from rearranging the equation for mass, as a function of radius.
[itex]\frac{r}{L}M=m[/itex], I made M in terms of small m (big M is the total mass, small m is the mass from 0 to r).
I assume you are measuring r from the fixed end of the rope, i.e. the centre of rotation. What contributes to the tension at that point - the rope at radius < r or the rope at radius > r?
At the point r, all the force is from r<, ah, I think I get it.
The question is asking the force AT r that is from the REST of the rope?
Exactly.
FAQ: Whirling Rope - Find the Tension at Position r
What is a whirling rope?
A whirling rope is a rope that is being spun around in a circular motion, either by holding one end and swinging the other end in a circle, or by having both ends attached to a central point and rotating the entire rope.
What is the tension in a whirling rope?
The tension in a whirling rope is the force that is applied by the rope on any object that is attached to it or that it is supporting. It is the force that keeps the rope taut and allows it to maintain its circular motion.
How do you find the tension at a specific position in a whirling rope?
To find the tension at a specific position in a whirling rope, you can use the formula T = (mv^2)/r, where T is the tension, m is the mass of the object attached to the rope, v is the velocity of the object, and r is the radius or distance from the central point of rotation.
What factors affect the tension in a whirling rope?
The tension in a whirling rope is affected by several factors, including the mass of the object attached to the rope, the velocity at which the object is moving, and the radius or distance from the central point of rotation. Additionally, the length and thickness of the rope can also impact the tension.
Why is it important to find the tension in a whirling rope?
Finding the tension in a whirling rope is important for understanding the forces acting on the rope and any objects attached to it. It can also be useful for predicting the behavior of the rope and ensuring that it can support the weight of any objects attached to it without breaking. Additionally, knowing the tension can help with calculations and experiments involving the rope.
