Why 8k Downscaled to 4k is very close to 8k Direct
The discussion centers on the differences between 8K and 4K television resolutions, emphasizing that while 8K TVs provide a noticeable improvement over 4K, downscaling 8K content to 4K can yield superior results compared to native 4K sources. Harmonic's findings suggest that downscaled 8K content is nearly indistinguishable from direct 8K output on standard-sized screens, leading to the conclusion that production may shift to 8K while viewing remains in 4K until larger screen sizes become common. The conversation also delves into the technology behind digital cameras, specifically the Bryce Bayer filter, which allows sensors to capture color information through a mosaic pattern. This technology explains why an 8K camera's output, despite being labeled as such, is effectively enhanced when downscaled to 4K, providing a richer image quality than a native 4K camera.
This is the first post in a series I plan on creating a Video Codec based only on AI.
First a while ago now I did a post on 8k vs 4k
https://www.physicsforums.com/threa...choose-the-right-tv-size.982481/#post-6283071
One of the takeaways was:
'First despite what others will tell you, you can see a difference in 8k TV’s compared to 4k. The question is why - and that’s where its surprising. What Harmonic found from 8k and 4k sources into 8k TV’s is 8K looked substantially better. But then they applied (hopefully high quality) down-scaling on the the 8k to make it 4k and compared that to the 4k direct. Surprisingly the down-scaled 8K looked substantially better on the 4k or 8k TV. Now it was very close to the 8K direct into both TV’s. In fact people then found it very difficult to tell the difference between the two on normal size screens of say 65 inchs (the one I have). Conclusion - Harmonic believes we will switch to production in 8K but watch it in 4k - at least initially until screen sizes increase substantially.'
It's one thing to notice something, it is another to understand why. It perplexed me until I understood how TV cameras work, and the Bryce Filter.
It allows sensors (which only record light intensity) to record light wavelength and is used in nearly all modern digital cameras. This filter uses a mosaic pattern of two parts, green, one part red, and one part blue, to interpret the colour information arriving at the sensor. Two pixels of green is used because the eye is more sensitive to green. Once recorded, digital algorithms are applied to interpolate or "demosaic" the resulting Bayer pattern and turn it into full-fledged colour data for the image. This means an 8k camera is not 8k - it gives an 8k output, but that is done by trickery to make it seem like 8k. However, if you downscale it to 4k, you get a better source than a 4k camera that uses the same trickery. That's why you get most of the benefits of 8k at 4k.
Thanks
Bill
Likes phinds, sbrothy, FactChecker and 2 others
Computer science news on Phys.org
Thanks
Bill
This sent me on a ridiculously long wikiwalk learning more about cameras and filtering than I'll ever need or, indeed remember. :P
Incidentally, Wikipedia refers to your Bryce filter as the Bayes filter. Same person though. Inconsequent detail, I know.
I know, but it was Bryce Bayer.
Not to be confused with Bayes filter.
I see. Well no surprise I got confused. I must've contracted a bad case of tunnelvision on that wikiwalk. A shame Jeopardy never calls with all the weird facts one picks up. :)
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
