Why Ampere is Not a SI Unit? A Brief Overview
The Ampere is considered a base unit in the SI system, defined by the force between parallel conductors rather than directly in terms of charge per second. While the Coulomb is a derived unit, the Ampere is treated as fundamental because measuring current is more precise than measuring charge. Despite this, realizing the Ampere accurately remains challenging, with current standards often derived from other units like the Volt and Ohm. Recent advancements in metrology aim to establish a current standard that could define the Ampere in terms of charge per second, leveraging the higher accuracy of time measurements. Overall, the discussion highlights the complexities in defining and measuring electrical units within the SI framework.
trust143_raj
Why ampere is not a S.I unit?
The Ampere is even a base unit in the SI.
Sorry i posted the wrong question? I tried to say why Ampere is the basic/fundamental unit although it is derived from charge/time(columb/sec)
Did you try google?
An amp is defined in terms of the current required to achieve a certain force between parallel conductors. Not in terms of Coulomb per sec.
With the notable exception of the kilogram, the SI base units are defined in a way as to make the units independently observable. In SI terminology, the coulomb is a derived unit. The reason is that measuring an ampere is a considerably easier (and more precise) task than is measuring a coulomb.
In the SI unit system current is the fundamental quantity and charge is a derived quantity (1 C = 1 A * 1 s).
The reason is simply that current is easier to measure precisely than charge.
Edit: I see D H was faster than I was
But it is still a very very difficult experiment if the accuracy is to be good enough. No one has -as far as I know- actually realized the Ampere this is way in quite a while (although I am sure there are a few old setups around).
In the "real world" the Ampere actually a derived unit, calculated from the realization of the Volt (Josephson effect) and the Ohm (quantum hall effect).
One of the big topics in metrology over the past few years has been to come up with a useful current standard, something that would allow us to define current in term of charges/second OR to realize the Ampere in terms of time, the latter would be useful since we can meaure time with higher accuracy than anything else (this is how the Volt is realzied. V=Kj*f, Kj being the Josephson constant adn f the frequency)
