Why an antenna cannot receive analogue baseband signal of 0-4000Hz?
  • Thread starter Thread starter dandeliondrea
    Antenna Signal
Analogue baseband signals of 0-4000Hz cannot be effectively received by antennas due to their extremely long wavelengths, which make antenna construction impractical. Modulation is necessary to shift these signals to higher carrier frequencies, such as 60-64KHz, allowing for feasible antenna design. While large antennas can be built for low frequencies, practical communication systems typically operate in higher frequency ranges, such as MHz, for efficiency. The size and shape of an antenna directly influence the voltage it generates, which is crucial for signal detection. Ultimately, effective antenna design requires balancing frequency and size constraints to facilitate communication.
dandeliondrea
Modulation is the process of impressing an information bearing signal to a carrier for effective transmission over a long distance. example Am and FM used in radio transmission
Analogue baseband signals of 0-4000Hz are shifted to 60-64Khz range.
Communication systems often do not carry signals in baseband (with the exception of local loop)
Wavelength of a radio wave in free space is the speed of light/the frequency.
That means a 4KHz voice signal has a wave length of 75000m (300000/4). We can't possibly make an antenna to receive such signals
I heard we need a very large antenna to receive analogue baseband signal of 0-4000Hz? why?
If you want to send out a signal a 4 KHz, then yes, for the most part we can't make a resonant antenna due to the size constraints (but take a look at the naval ELF submarine antennas). However, by modulating the frequency at a much higher carrier frequency, then we only need to receive at the carrier frequency. So if the carrier frequency is say 62 KHz, then we can design an antenna, but it will still be friggin huge. I think MHz would be a better starting band for carrier frequencies as we have seen with radio and television standards.
You have to have an antenna to detect or receive electromagnetic radiation and information carried by it. A receiving antenna can be a piece of wire, or even your own finger.
Pull out your Sound Blaster plug and rub the tip with a finger. You should be able to hear mains noise in your loudspeakers.
An other way of demonstrating this is touching an oscilloscope probe tip with your finger. You should be able to see mains frequency and much more.
How much voltage your antenna generates, depends on the field strength and the size and shape of the antenna.
Thanks for the explanation.
Another way may be to note that in antenna design, making the frequency spread \Delta\omega/\omega small makes the design easier to implement.
i see, thanks for the information.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Someone who shows interest in science is initially a welcome development. So are fresh ideas from unexpected quarters. In contrast, there is a scientific community that is meticulously organized down to the last detail, allowing little to no external influence. With the invention of social media and other sites on the internet competing for content, unprecedented opportunities have opened up for...
I am going through this course on collision detection: https://siggraphcontact.github.io/ In this link is a PDF called course notes. Scrolling down to section 1.3, called constraints. In this section it is said that we can write bilateral constraints as ##\phi(\mathbf{x}) = 0## and unilateral constraints as ##\phi(\mathbf{x}) \ge 0##. I understand that, but then it says that these constraints call also be written as: $$\mathbf{J} \mathbf{u} = 0, \mathbf{J} \mathbf{u} \ge 0,$$ where...
