Why Angular momentum is important?
In summary, angular momentum is important in quantum mechanics because it describes the rotational analog of momentum. It is also important because the same mathematical formalism that describes "real" angular momentum (a particle spinning around an axis) also turns out to describe some other internal degree of freedom (which we call spin) which is also extremely important.
russell23
Hi,
May be a trivial question. But, "Why angular momentum is an important physical quantity in quantum mechanics?".
Could anyone explain me?
Why (linear) momentum is important? Angular momentum is just the rotational analog of that. If you move something in a straight line, you get momentum. If you rotate it, you get angular momentum. If you want to describe an object, you should include both.
In quantum mechanics, angular momentum is particularly important, because the same mathematical formalism that describes "real" angular momentum (a particle spinning around an axis) also turns out to describe some other internal degree of freedom (which we, confusingly, call spin) which is also extremely important.
Although, care needs be taken over that characterisation. Spin certain does contribute to the angular momentum of the system --- see the Einstein-de Hass effect. Furthermore, we know that neither spatial angular momentum (L) or spin (S) alone is a symmetry of the universe, but that the combined J is.
Another reason is that the angular momentum of charged particles relates to the concept of magnetic moment from electrodynamics, and so is responsible for creating magnetic fields within the atom (which is how you explain paramagnetism, for example) and governs how the atom interacts with external magnetic fields.
The answer is a group theoretical one. A system generally has one or more wavefunctions with the same energy, and so a general wavefunction with that energy is a linear combination of those wavefunctions. Different wavefunctions with the same energy are thus related to each other by matrix multiplication, and these matrices form groups (in the group theory sense).
For consistency, these groups are the symmetry groups of the system (e.g., the rotation group), and one of the most important features steps in the development of quantum mechanics was the (re)discovery of groups. If you knew the symmetries of a system, you could already tell a lot about it, like selection rules, degeneracy, etc., without really "solving" anything. Different systems with the same symmetries look very much the same.
For systems with rotational symmetry, states come in representations of the rotation group SO(3), and these representations are labeled by quantum numbers which also happen to correspond to angular momentum eigenvalues. But they are very general. Try to solve for the electromagnetic field of some localized current distribution (a problem that has nothing to do with quantum mechanics) and the same "quantum numbers" will appear in the spherical harmonic functions.
Adding: Energy levels of certain systems, look for instance on the Nuclear Shell model.
FAQ: Why Angular momentum is important?
Why is Angular Momentum Important in Physics?
Angular momentum is important in physics because it is a fundamental property of rotating objects. It helps us understand the motion and stability of objects, and is a crucial concept in fields such as mechanics, astrophysics, and quantum physics.
How is Angular Momentum Conserved?
According to the law of conservation of angular momentum, the total angular momentum of a system remains constant in the absence of external torques. This means that if no external forces act on a rotating object, its angular momentum will remain constant.
What are the Applications of Angular Momentum?
Angular momentum has numerous practical applications, such as in the design of vehicles and machines that rotate, like turbines and gyros. It is also used in fields such as robotics, aerospace engineering, and even sports, where understanding the angular momentum of a spinning ball is crucial.
How is Angular Momentum Different from Linear Momentum?
Angular momentum and linear momentum are both measures of an object's motion, but they differ in how they are calculated. While linear momentum is the product of an object's mass and velocity, angular momentum is the product of its moment of inertia and angular velocity.
Why is Understanding Angular Momentum Important in Quantum Mechanics?
In quantum mechanics, angular momentum is a quantized property, meaning it can only take on certain discrete values. This is important in understanding the behavior of subatomic particles, as their angular momentum can determine their energy levels and interactions with other particles.
