- #36
- 27,441
- 18,913
That's a deficiency in your knowldege!james fairclear said:To my knowledge there is no evidence to support your claim that "all clocks tick physically at the same rate"?
The geometry of spacetime.james fairclear said:Regardless of the different paths taken how is it possible for 3 previously synchronised clocks to indicate different times without their respective tick rates having changed at some point?
There is a voluminous literature on experimental tests of Special Relativity. Please familiarize yourself with it. The claim in question is called the "clock hypothesis" and is an integral part of Special Relativity.james fairclear said:Can you point me to a link that discusses evidence for this claim?
Consider an analogy: you and I both drive from New York to Washington, DC. You take the direct route, straight down the East Coast; I take a roundabout route by way of Pittsburgh, PA. The odometer on my car registers more distance traveled when we meet up again than yours does. Does that mean the "distance rate" of my odometer was different from yours? No; both of our odometers registered one mile per mile. The route I took just had more miles in it than yours: our paths had different lengths.james fairclear said:Regardless of the different paths taken how is it possible for 3 previously synchronised clocks to indicate different times without their respective tick rates having changed at some point?
It's the operational definition of a clock. It must measure time accurately. That's what a clock does.james fairclear said:Can you point me to a link that discusses evidence for this claim?
As you say SR is a theory of space and time. The definition of time is "that which is measured by clocks" so the workings of clocks are inextricably bound up with time.PeroK said:The geometry of spacetime.
Special Relativity is theory of space and time; not a theory about the mechanical workings of clocks.
If so then the results of the Hafele Keating experiment disprove the principle.PeroK said:The principle of relativity demands that a clock is unaffected by motion
I doubt that Hafele and Keating would have agreed with that!james fairclear said:If so then the results of the Hafele Keating experiment disprove the principle.
That's simply not the case. Motion is relative, not physical. Absolute motion cannot be detected. So, there is nothing physical about relative motion for a clock to be affected by. A good reference for this is Einstein's original 1905 paper:james fairclear said:Regardless of whether or not time is a separate entity something must be physically affecting the tick rate of clocks in motion as otherwise their indicated times would not vary.
PeroK said:That's simply not the case. Motion is relative, not physical. Absolute motion cannot be detected. So, there is nothing physical about relative motion for a clock to be affected by. A good reference for this is Einstein's original 1905 paper:
It is known that Maxwell’s electrodynamics—as usually understood at the
present time—when applied to moving bodies, leads to asymmetries which do
not appear to be inherent in the phenomena ...
Examples of this sort, together with the unsuccessful attempts to discover
any motion of the Earth relatively to the “light medium,” suggest that the
phenomena of electrodynamics as well as of mechanics possesses no properties
corresponding to the idea of absolute rest.
They suggest rather that the same laws of electrodynamics and optics will be valid for all frames of reference for which the equations of mechanics hold good. We will raise this conjecture (the purport
of which will hereafter be called the “Principle of Relativity”) to the status of a postulate.
In summary, you are missing the first postulate of relativity and thereby misinterpreting all of the theory of relativity.
That a state of motion cannot be experimentally distinguished from a state of rest. For example, you might claim to be at rest sitting at your computer. But, the Earth is orbitting the Sun at about ##30,000 m/s##. You can, of course, measure that relative motion. The question is: what is physically different about you to the tune of ##30,000m/s##?james fairclear said:There is nothing stated or implied in the first postulate that motion is not something physical.
What exactly do you mean by your statement "motion is not physical"?
The "stationary" clock is in motion relative to the "moving" clock. It, likewise, ought to be physically altered by the relative motion. Neither clock can claim to be "really" at rest or "really" moving. That is what Einstein was saying above.james fairclear said:As to whether there any physical changes to an object in motion is a separate issue. Observationally there are physical changes to synchronised clocks when put in motion as they cease to be synchronised with the relatively stationary clock.
All clocks tick at their highest tick rate in a reference frame where they are at rest; and all other clocks are ticking relatively slowly as measured by that clock. Every clock can claim to be ticking normally. As indeed it is.james fairclear said:A clock ticking at its highest possible tick rate could be considered to be at rest relative to any other clock ticking at a slower rate.
The discrepancy between the clock on the ground and the clock on the aircraft is not explained by the motion of the aircraft. Consider that the ground clock was moving with the Earth's rotation, with the orbit of the Earth around the sun, with the sun's orbit around the galactic core, and the galaxy's drift through intergalactic space... What makes the trajectory of the Earth clock so special?james fairclear said:If so then the results of the Hafele Keating experiment disprove the principle.
This argument is wrong. You have already been told why it is wrong in this thread. Consider the odometer analogy in post #40. Do the different odometer readings for drivers who take different routes between two points mean that "something must be physically affecting the tick rate" of the odometers?james fairclear said:something must be physically affecting the tick rate of clocks in motion as otherwise their indicated times would not vary.
No, they don't. You have already been told why in this thread. See above.james fairclear said:If so then the results of the Hafele Keating experiment disprove the principle.
"Not physical" in this connection means "not invariant" (because "motion" is frame-dependent) or "not directly observable" (because there is no experiment you can do that will tell you that you are "moving" in any absolute sense). So your statement is wrong; the first postulate does say that motion is "not physical" in this sense.james fairclear said:There is nothing stated or implied in the first postulate that motion is not something physical.
And the question as you originally phrased it is not well-defined, which is why it does not have a single well-defined answer.james fairclear said:My original question is "Considering an atom within a rigid body, does the angular momentum of an electron within the atom vary when the body is put in motion?"
Because if "angular momentum" includes "orbital angular momentum around some chosen external point", then an electron in an atom at rest relative to that point does have different "angular momentum" than an electron in an atom that is moving relative to that point. But this definition of "angular momentum" is frame-dependent; it's not something you directly measure, it's something you calculate after you've chosen a particular point, which implies choosing a particular frame in which that point is at rest.james fairclear said:Some of the responses provided on this forum suggest that the answer is yes
No, it implies that some definitions of "angular momentum" are frame-dependent. See above.james fairclear said:which implies that motion will have a physical effect.
"Put into motion" is ambiguous. If it just means choosing a different frame of reference without doing anything to the body itself, obviously this has no physical effect. But if it means exerting an actual force on the body, which will change its motion relative to other bodies, obviously this does have a physical effect. But if you use the same term to refer to both of these things, obviously you're just going to confuse yourself.james fairclear said:If there is no physical effect on a body when put into motion
This is fallacious reasoning, both because of the issue just stated above and because "relativistic effects" include things that are directly observable.james fairclear said:there should be no need to take into account relativistic effects.
Wrong, for two reasons.james fairclear said:A clock ticking at its highest possible tick rate could be considered to be at rest relative to any other clock ticking at a slower rate.
"All clocks tick at their highest tick rate in a reference frame where they are at rest".PeroK said:The "stationary" clock is in motion relative to the "moving" clock. It, likewise, ought to be physically altered by the relative motion. Neither clock can claim to be "really" at rest or "really" moving. That is what Einstein was saying above.
Can you give an example of an object that you believe is at rest? That definitely is not moving?james fairclear said:A clock can claim to be at rest if its tick rate is the highest possible tick rate.
Your driving analogy is only applicable to time dilation if the odometers measure the same distance despite the fact that we have traveled different distances.PeterDonis said:Consider an analogy: you and I both drive from New York to Washington, DC. You take the direct route, straight down the East Coast; I take a roundabout route by way of Pittsburgh, PA. The odometer on my car registers more distance traveled when we meet up again than yours does. Does that mean the "distance rate" of my odometer was different from yours? No; both of our odometers registered one mile per mile. The route I took just had more miles in it than yours: our paths had different lengths.
Similarly, in a "twin paradox" scenario (or a "triplet" scenario such as the H-K experiment), everyone's clock ticks at the same rate: one second per second. But the different paths through spacetime that each observer takes have different numbers of seconds in them: they have different spacetime lengths. That's why the different observers have aged differently when they meet up again: "elapsed age" is a measure of (timelike) distance traveled through spacetime, just as elapsed odometer mileage on a car is a measure of distance traveled through space.
The discrepancy between the clock on the ground and the clock on the aircraft can only be explained by the relative motion between the clocks as that was the only material difference between the 2 clocks in the experiment.Nugatory said:The discrepancy between the clock on the ground and the clock on the aircraft is not explained by the motion of the aircraft. Consider that the ground clock was moving with the Earth's rotation, with the orbit of the Earth around the sun, with the sun's orbit around the galactic core, and the galaxy's drift through intergalactic space... What makes the trajectory of the Earth clock so special?
No, from that definition it follows that what you are calling the tick rate is a frame-dependent quantity.james fairclear said:From this definition it follows that the tick rate of a clock will never vary which is contradicted by the evidence of the Hafele Keating experiment.
Wrong. Odometers measure distance traveled through space. Clocks measure distance traveled through spacetime. The analogy is valid.james fairclear said:Your driving analogy is only applicable to time dilation if the odometers measure the same distance despite the fact that we have traveled different distances.
No, the relative motion was not the only material difference. The different clocks took different paths through spacetime; that is the material difference. The relative motion is one side effect of that, but not the only one.james fairclear said:The discrepancy between the clock on the ground and the clock on the aircraft can only be explained by the relative motion between the clocks as that was the only material difference between the 2 clocks in the experiment.
Which, since he was the OP of the thread, means the thread is now closed.Nugatory said:You will no longer be able to post into this thread.
