Why are more polarized bonds weaker (Acid dissociation)?
  • Thread starter Thread starter yucheng
    Polarity
The discussion centers on the acidity of hydrofluoric acid (HF) and the comparison of bond strengths between H-F and H-I. It highlights that the weak acidity of HF in dilute solutions is attributed to the strong H-F bond and the high dissolution enthalpy of HF, which offsets the negative enthalpy of hydration of the fluoride ion. The argument that the H-F bond is stronger than the H-I bond is based on bond enthalpies, but for acid dissociation, one must consider the formation of ions and their hydration, suggesting that the initial argument may be oversimplified. Additionally, the discussion touches on the influence of electron-donating groups on the O-H bond strength in carboxylic acids, noting that these groups can reduce bond polarity and thus increase bond strength. The relationship between bond polarity and strength is questioned, with a focus on why polar bonds tend to be weaker than non-polar bonds.
yucheng
Wikipedia says that:
The weak acidity in dilute solution is sometimes attributed to the high H—F bond strength, which combines with the high dissolution enthalpy of HF to outweigh the more negative enthalpy of hydration of the fluoride ion.
(https://en.wikipedia.org/wiki/Hydrofluoric_acid)
(the H-F bond is highly polar compared to the H-I bond)
(H-F bond is stronger than H-I bond)
It is a common argument to say that H-F bond is stronger than H-I bond on the basis of bond enthalpies:
$$\text{HX} -> \text{H(g)} + \text{X(g)}$$.
However, for dissociation of acids, we must actually consider (hence the electron affinity comes in)
$$\text{HX} -> \text{H}^+(g) + \text{X}^-(g)$$,
and then the hydration of the ions, no? Does this mean the argument given above is... inaccurate, though it works?
____________
For O-H bonds in carboxylic acids, electron donating group causes the O-H bond to be less polar hence stronger.
Carboxylic acids, https://en.wikipedia.org/wiki/Inductive_effect
Why Is polarity related to bond strength? Why are polar bonds weaker than non-polar bonds?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
