Why (ax^2 + bx + c) = a(x-α)(x-β)?
  • Thread starter Thread starter Atran
The discussion explains the relationship between the standard form of a quadratic equation, Ax² + Bx + C, and its factored form, A(x - α)(x - β). It demonstrates this with the example of the polynomial 3x² - 2x - 1, showing how it factors into 3(x + 1/3)(x - 1). The coefficients of the quadratic are linked to the roots through the relationships x₁ + x₂ = -B/A and x₁ * x₂ = C/A. The discussion concludes that the factored form accurately represents the original polynomial by confirming the relationships between the coefficients and the roots. Understanding this connection is essential for solving quadratic equations effectively.
Atran
Say, 3x2 - 2x - 1 = 0
Then: x1 = -1/3, x2 = 1
Therefore: k * (x + 1/3) (x - 1) = 3x2 - 2x - 1
Why is k = 3?
Why, Ax^{2} + Bx + C = A (x-\alpha) (x-\beta)?
Thanks for help.
Mathematics news on Phys.org
Well the polynomial ##3x^2 - 2x -1 = (3x+1)(x-1) = 3 (x+1/3)(x-1)##.
Also solving the equation ##3x^2-2x-1 = 0## is equivalent to ##x^2 - \frac{2}{3}x - \frac{1}{3} = 0##.
And even further notice that when you take ##A(x-\alpha)(x-\beta)## and expand the coefficient of ##x^2## is equal to A.
To answer the question:
Thanks for help.
Well, you have in general
x_{1,2}=\frac{-b\pm \sqrt{b^2-4ac}}{2a}
and
x_1=\frac{-b+ \sqrt{b^2-4ac}}{2a}
x_2=\frac{-b - \sqrt{b^2-4ac}}{2a}We also have
a(x_1 + x_2)=a(\frac{-b+ \sqrt{b^2-4ac}}{2a} + \frac{-b- \sqrt{b^2-4ac}}{2a}) = a(\frac{-2b}{2a}) = a(\frac{-b}{a}) = -b
and if a(x_1+x_2) = -b,
a(-x_1-x_2) = b
We also have
(x_1)\cdot(x_2)=(\frac{-b+ \sqrt{b^2-4ac}}{2a})\cdot(\frac{-b- \sqrt{b^2-4ac}}{2a})
which after a little work gets you (x_1) \cdot (x_2)= \frac{c}{a}. Equivalently we can have a(x_1)\cdot(x_2) = c
If we substitute our b and c into ax^2+bx+c we get
ax^2+bx+c = ax^2+ a(-x_1-x_2)x + a(x_1)\cdot (x_2)
= a(x^2 -x\cdot x_1 -x\cdot x_2 + (x_1)\cdot(x_2))
= a(x-x_2)(x-x_1)
In the above step you factorize, it should be clear how you get there if you try to expand(x-x_2)(x-x_1).
So that's why ax^2+bx+c = a(x-x_2)(x-x_1)
Likes 1 person
Thank you for the answers.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
